Up to 20% off select tools
How to build a computer
Views: 2.7K
View statistics:
Past 24 Hours:
9
Past 7 Days:
41
Past 30 Days:
200
All Time:
2,727
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
    1. How to build a computer, Power supply: step 1, image 1 of 2 How to build a computer, Power supply: step 1, image 2 of 2
      • Locate the power supply INSIDE the box.
      Ask FixBot
    2. How to build a computer, Ventilation box: step 2, image 1 of 1
      • Place the fan on the back of the case and screw in the four corners.
      • Observe the orientation of the fan, so that its air flow circulates from the inside to the outside
      Ask FixBot
    3. How to build a computer, Processor: step 3, image 1 of 1
      • Place the processor in its socket, respecting the pin orientation.
      • Do not force it, to prevent the pins from bending. It should go in smoothly.
      Ask FixBot
    4. How to build a computer, Processor cooling: step 4, image 1 of 1
      • Apply the thermal paste on the processor.
      Ask FixBot
    5. How to build a computer, Processor Cooling Fan: step 5, image 1 of 1
      • Fit on top the cooling with the fan, with the thermal paste between the two.
      • Connect the fan to the motherboard.
      Ask FixBot
    6. How to build a computer, RAM Memory: step 6, image 1 of 1
      • Open the socket tabs on the motherboard.
      • Once the module is correctly oriented, press it all the way down.
      Ask FixBot
    7. How to build a computer, Hard Disk: step 7, image 1 of 1
      • Place the hard disk on its rails.
      • Slide the hard drive in, until it is aligned with the screw holes. Screw it on both sides.
      • Connect the supplied SATA cable to the hard disk and the motherboard.
      • Connect the power cable coming from the power supply unit.
      Ask FixBot
    8. How to build a computer, Optical Unit: step 8, image 1 of 1
      • Place the hard disk on its rails, inserting it from the outside to the inside.
      • Previously remove the external cover of the box at the desired height.
      • Screw the unit on both sides.
      • Connect the supplied SATA cable to the drive and to the motherboard.
      Ask FixBot
To disassemble your device, follow these instructions in reverse order.
6 other people completed this guide.
Special thanks to these translators:
es en
100%
Penny is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Francisco Ortiz
337 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 41
Past 30 Days: 200
All Time: 2,727
