Up to 20% off select tools
How to align Razor A steering
Views: 33K
View statistics:
Past 24 Hours:
7
Past 7 Days:
23
Past 30 Days:
136
All Time:
32,613
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Sometimes a scooter will move in a different direction than the user directs it. This guide will demonstrate how to align the steering column with the front wheel, and so that the scooter moves properly in the right direction.
    1. How to align Razor A steering, How to align Razor A steering: step 1, image 1 of 3 How to align Razor A steering, How to align Razor A steering: step 1, image 2 of 3 How to align Razor A steering, How to align Razor A steering: step 1, image 3 of 3
      • Locate the collar clamp near the base of the steering column.
      • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
      • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
      Ask FixBot
    2. How to align Razor A steering: step 2, image 1 of 2 How to align Razor A steering: step 2, image 2 of 2
      • Firmly grasp the steering column and turn the wheel by hand.
      • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
      • The second picture above shows a correct alignment of the steering column from this view.
      Ask FixBot
Finish Line
17 other people completed this guide.
Author
with
Jordyn
565 Reputation
5 Guides authored
Cal Poly, Team 9-13, Amido Fall 2012 Member of Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Members
60 Guides authored
4 Guide Comments
This is so unhelpful.
Linh Tran - Reply Share
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Reply Share
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Reply Share
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - Reply Share
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 136
All Time: 32,613
