How to adjust Razor A steering column
    1. How to adjust Razor A steering column, How to adjust Razor A steering column: step 1, image 1 of 2 How to adjust Razor A steering column, How to adjust Razor A steering column: step 1, image 2 of 2
      • Locate the tightening assembly. The tightening assembly consists of:
      • An upper nut
      • A lower nut
      Ask FixBot
    2. How to adjust Razor A steering column: step 2, image 1 of 1
      • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
      • If loosening the steering column, follow these steps:
      • Turn the upper nut counterclockwise.
      • Turn the lower nut counterclockwise until it is tight against the upper nut.
      • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
      • If tightening the steering column, follow these steps:
      • Turn the lower nut clockwise until reaching the desired steering column tightness.
      • Turn the upper nut clockwise until it is tight against the lower nut.
      Ask FixBot
Finish Line
4 other people completed this guide.
Jordyn
565 Reputation
5 Guides authored
Cal Poly, Team 9-13, Amido Fall 2012 Member of Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Members
60 Guides authored
8 Guide Comments
what move it with your hands? - didn't help
Heather McCasland - Reply Share
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 - Reply Share
Thanks you! Why doesn't the owners manual have this?
Jessica - Reply Share
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Reply Share
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Reply Share
Past 24 Hours: 10
Past 7 Days: 29
Past 30 Days: 160
All Time: 44,325
