How to Winterize a Sprinkler System
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
94
All Time:
1,341
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Winter is around the corner, which means that it’s getting cold outside, putting your sprinkler system lines to risk of freezing. When water freezes, it expands. This hydro-expansion can cause fittings, sprinklers, valves, pumps, pipes and other parts of irrigation systems to burst and break. Draining your system of all water is the only way to ensure that it will still be in working order when spring arrives. Luckily, there’s a way that you can take care of that and blow the water out of the system so it doesn’t freeze. This is an easy and fast guide showing you exactly what to do to get your sprinkler system ready for the winter.
    1. How to Winterize a Sprinkler System, How to Winterize a Sprinkler System: step 1, image 1 of 2 How to Winterize a Sprinkler System, How to Winterize a Sprinkler System: step 1, image 2 of 2
      • Shut the water supply off to the irrigation system. (usually found in the utility room or basement)
      Ask FixBot
    2. How to Winterize a Sprinkler System: step 2, image 1 of 1
      • Obtain an air compressor. (you can rent one from the local Home Depot)
      Ask FixBot
    3. How to Winterize a Sprinkler System: step 3, image 1 of 3 How to Winterize a Sprinkler System: step 3, image 2 of 3 How to Winterize a Sprinkler System: step 3, image 3 of 3
      • Connect a hose to the compressor, and one to the water line (in basement).
      Ask FixBot
    4. How to Winterize a Sprinkler System: step 4, image 1 of 1
      • Turn the compressor on.
      Ask FixBot
    5. How to Winterize a Sprinkler System: step 5, image 1 of 1
      • Start manually turning on each station of the system one by one.
      Ask FixBot
    6. How to Winterize a Sprinkler System: step 6, image 1 of 1
      • Let the air blow the water out for about 2 minutes per station.
      Ask FixBot
    7. How to Winterize a Sprinkler System: step 7, image 1 of 3 How to Winterize a Sprinkler System: step 7, image 2 of 3 How to Winterize a Sprinkler System: step 7, image 3 of 3
      • Unplug the hose from the compressor and the water line.
      Ask FixBot
    8. How to Winterize a Sprinkler System: step 8, image 1 of 2 How to Winterize a Sprinkler System: step 8, image 2 of 2
      • Turn the air compressor off and then turn the sprinkler system off from the control panel outside.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 94
All Time: 1,341
