How to Winterize Sprinkler System
  1. How to Winterize Sprinkler System, How to Winterize Sprinkler System: step 1, image 1 of 2 How to Winterize Sprinkler System, How to Winterize Sprinkler System: step 1, image 2 of 2
    • Shut the water supply off to the irrigation system. (usually found in the utility room or basement)
    Ask FixBot
  2. How to Winterize Sprinkler System: step 2, image 1 of 1
    • Obtain an air compressor. (you can rent one from the local Home Depot)
    Ask FixBot
  3. How to Winterize Sprinkler System: step 3, image 1 of 3 How to Winterize Sprinkler System: step 3, image 2 of 3 How to Winterize Sprinkler System: step 3, image 3 of 3
    • Connect a hose to the compressor, and one to the water line (in basement).
    Ask FixBot
  4. How to Winterize Sprinkler System: step 4, image 1 of 1
    • Turn the compressor on.
    Ask FixBot
  5. How to Winterize Sprinkler System: step 5, image 1 of 1
    • Start manually turning on each station of the system one by one.
    Ask FixBot
  6. How to Winterize Sprinkler System: step 6, image 1 of 1
    • Let the air blow the water out for about 2 minutes per station.
    Ask FixBot
  7. How to Winterize Sprinkler System: step 7, image 1 of 3 How to Winterize Sprinkler System: step 7, image 2 of 3 How to Winterize Sprinkler System: step 7, image 3 of 3
    • Unplug the hose from the compressor and the water line.
    Ask FixBot
  8. How to Winterize Sprinkler System: step 8, image 1 of 2 How to Winterize Sprinkler System: step 8, image 2 of 2
    • Turn the air compressor off and then turn the sprinkler system off from the control panel outside.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 33
All Time: 1,127
