Up to 20% off select tools
How to Use Time Machine on macOS
Views: 3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
30
Past 30 Days:
126
All Time:
2,985
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Time Machine, a built-in function to macOS since OS X 10.5 Leopard, is the easiest way to back up and recover your Mac from hard drive failure. Before beginning any Mac repairs, follow this guide to ensure you have protection against any data loss.
This guide includes some optional steps, such as enabling backups to multiple drives.
      • Select System Preferences from the Apple menu.
      • Click the Time Machine icon in the bottom row.
      Ask FixBot
      • If you haven't already, plug in your external drive, or join to the network your NAS is connected to.
      • Click the Select Backup Disk button.
      • Select the disk you'd like to make backups to from the list.
      • External backup drives must be HFS (Mac OS X Journaled) formatted to work with Time Machine, not APFS, NTFS, etc.
      • Networked devices should appear automatically on this list. Consult your NAS' manual for assistance.
      • Check the Encrypt backups checkbox for additional data security, especially if your backup device is portable.
      Ask FixBot
      • If you chose not to encrypt your backups, you can skip this step.
      • Enter an encryption password for your Time Machine backups here, or let Apple generate one for you.
      • Store this password in a safe place! If you lose it, you will not be able to access any of your backup data or recover your machine.
      Ask FixBot
      • If you selected a network backup location, you may be asked to enter network login credentials at this point. Consult your NAS' documentation for more information.
      • Check the Back up automatically box if it isn't checked already, and Time Machine will be enabled!
      • To begin your first backup immediately, right click your backup drive and select Back Up to "Drive Name" Now.
      Ask FixBot
      • Time Machine supports multiple backup destinations for backup redundancy, if you have a second external drive or NAS.
      • Select Select Disk to select another drive.
      • Repeat steps 2 and 3 to select another backup disk from the list, and optionally enable encryption.
      Ask FixBot
      • When asked if you want to replace the current backup disk or use both, select the Use Both option. This will enable backups to both drives concurrently.
      • To add three or more backup destinations, select the Add or Remove Backup Disk option. You may need to scroll through the list of backup drives to find it.
      • With multiple drives, Time Machine will make hourly backups as normal, backing up to the drive with the oldest backup first, so all drives remain as up-to-date as possible.
      • If a second backup drive isn't connected, Time Machine will continue backing up to connected drives, and will automatically update the backup when the drive is reconnected, perfect for off-site or long-term backups!
      Ask FixBot
      • Now that you have Time Machine configured, macOS has a built-in backup browser to recover accidentally deleted or modified files.
      • In the folder that contained the files you want to recover, click the Time Machine icon in your menu bar, and select Enter Time Machine.
      Ask FixBot
      • On the right side of your screen, there will be a timeline of backup dates you can scroll through. Select the date you want to recover from.
      • Click the file you want to restore, and select Restore.
      Ask FixBot
      • Time Machine also has full system restore functionality, in case of hard drive failure. You can also use this method to setup a new machine from a previously created backup.
      • Boot to macOS recovery by holding Command+R.
      • Select Restore from Time Machine Backup from the list of available options.
      Ask FixBot
      • Continue to the Restore Your System page.
      • Select your Time Machine backup from the list, and Continue.
      • Select the most recent backup of your drive, or the backup you need to restore, and Continue.
      • Your Mac will now restore the system from the backup you selected, and will restart upon completion.
      Ask FixBot
      • Time Machine backups can also be used as a data source in the built-in Migration Assistant app.
      • Open the Migration Assistant app if you've already setup macOS.
      • Select the From a Mac, Time Machine backup, or startup disk option in the list of transfer choices, and click Continue.
      • Select the backup drive icon in the list of choices, and click Continue.
      • If you backed up to a NAS and don't see it in the list, ensure you're connected to the same network.
      • You may be asked to enter a decryption password. Enter the one you chose previously, when configuring your backup.
      Ask FixBot
      • Choose the backup you want to use, likely the latest backup, and click Continue.
      • Select the information you want to transfer.
      • If you have a lot of content backed up, it may take several hours to restore entirely.
      Ask FixBot
That's it! Now you should know how to keep your data backed up using Time Machine, understand its more advanced features, and know how to restore a backup in the event of a failure.
4 other people completed this guide.
Author
with
Jonah Aragon
5,758 Reputation
5 Guides authored
Experimax Coon Rapids Member of Experimax Coon Rapids
Business
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 126
All Time: 2,985
