How to Use Diagnostic Modes on a Kenmore Washing Machine
Video Guide
This guide was transcribed from a YouTube video.
    • Use a 1/4" nut driver to remove the rear screws in this guide.
    Ask FixBot
    • Use the 1/4" nut driver to remove the harness-plate screw and the two top-panel screws from the rear of the washer.
    Ask FixBot
    • Pull the lid toward you, lift it upward, then push it back to let the top panel pivot on its rear hinges.
    Ask FixBot
    • Tape the washer lid closed before lifting the top panel to keep it from swinging open.
    • Rest the open top against a wall or brace it with a support so it cannot fall while you work.
    Ask FixBot
    • Remove the technician sheet from the front left corner inside the cabinet and keep it handy for code reference.
    Ask FixBot
    • With power connected rotate the cycle knob counter-clockwise until it reaches the 12 o’clock position completing one full turn.
    Ask FixBot
    • Turn the knob right three clicks, left one click, then right one click, pausing about half a second between each movement.
    • Confirm entry when every status LED flashes together.
    Ask FixBot
    • Rotate the knob clockwise to scroll through Error Code, Automatic Test, Manual Test, and Recalibration modes.
    Ask FixBot
    • Stop when only the Cycle Complete LED is lit and press Start to enter the error code menu.
    • Wait for the LEDs to flash once, indicating stored faults are ready to display.
    Ask FixBot
    • Turn the knob clockwise to view each of the four most recent fault codes.
    • If the Sensing Fill LED is lit the code begins with F; if it is dark the code begins with E.
    • Add the numbers shown by the other lit LEDs to complete the code and record it for spin or drain troubleshooting.
    Ask FixBot
    • After the fourth code turn the knob once more, then press and hold Start for about five seconds while all LEDs flash to erase the memory.
    Ask FixBot
    • Rotate to Automatic Test and press Start; the washer will fill, agitate, drain, and spin through every major function in roughly three minutes.
    • The lid lock engages during this test, blocking your view unless the lock is bypassed.
    Ask FixBot
    • Remove the two Torx screws securing the lid striker, slide the striker off, and insert it into the lid lock to simulate a closed lid.
    • Opening the lid during high-speed spin can cause injury or damage; observe at your own risk.
    Ask FixBot
    • Watch and listen as the washer moves through each step to identify any component that fails to actuate, fill, drain, or spin.
    Ask FixBot
    • Select Manual Test, press Start, then rotate the knob to the function you wish to test individually.
    • Choose Lid Lock first when you need to run agitation or spin tests.
    Ask FixBot
    • Press Start to begin the selected action and press it again to stop when finished.
    • Hold Start for three to four seconds to cancel manual mode and return the control to standby.
    Ask FixBot
    • From diagnostics rotate the knob four clicks clockwise until only the Rinse LED remains lit, then press Start.
    • Let the recalibration run for about two and a half minutes until all LEDs turn off.
    Ask FixBot
    • Lower the top panel onto the cabinet, slide it forward to seat the hinges, and tighten the two top panel screws and harness plate screw.
    Ask FixBot
    • Remove the tape, move the washer back into place, and resume normal use with diagnostics complete.
    Ask FixBot
Clear old codes, finish recalibration, and use the results you recorded to guide any follow-up troubleshooting. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,079 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 84
Past 30 Days: 323
All Time: 1,752
