Introduction
Use this guide to troubleshoot a Whirlpool washer with the newer console top, and compatible Maytag models with the same style console. You’ll learn where the hidden tech sheet is, how to enter Diagnostic Mode, how to read and clear error codes, how to run the automatic parts test, and how to run the factory calibration cycle (often called a factory reset). This diagnostic and calibration system differs from many other Whirlpool and Maytag washer models, and this style console doesn’t provide a manual parts test that can hold a single step indefinitely.
Step 2 Locate the hidden tech sheet
Pull the washer away from the wall to access the rear of the console.
Use a screwdriver to remove the single screw holding the wire cover in place.
Remove the wire cover.
Use a T20 Torx driver or a 1/4" nut driver to remove the five screws holding the console plate in place.
Remove the console plate and locate the hidden tech sheet inside the console area.
Step 3 Put the washer into standby
Make sure the washer is in standby with no lights displayed.
If you aren’t sure it’s in standby, unplug the washer for one minute, and plug it back in.
Step 4 Enter diagnostic mode
Press the same three-button sequence in order three times within eight seconds.
Watch for all console lights to flash to confirm the washer entered diagnostic mode.
Step 5 Troubleshoot when diagnostic mode won’t start
Press the Power button and try to select a mode.
If the washer powers on normally, unplug it, plug it back in, and retry the diagnostic entry sequence one or two more times.
Check the control board behind the console for a hidden flashing green LED that indicates the unit has power.
Step 6 Understand key numbers and active error codes
Use the tech sheet to identify the console key numbers, since each key is assigned a number.
If the washer starts flashing codes right away, go to the error code steps in this guide before running tests.
Step 7 Run the UI test mode
Press key number one, which is the Temperature key, to enter UI test mode.
Confirm entry by watching for all the lights to flash.
Turn the dial to scroll through 12 different light combinations.
After the combinations cycle, press the UI buttons to verify the console lights respond and the keys work.
Press and hold key number one for five seconds to exit UI test mode.
Step 8 Start the automatic parts test mode
Re-enter diagnostic mode if the washer isn’t currently in diagnostics.
Press key number two, then key number five, which are the Rinse and Start buttons.
If water is connected to the washer, it should begin filling immediately and run tests in the background.
Step 9 Control and exit the automatic test mode
Watch and listen during testing to confirm each function runs as the sequence progresses.
Use the Temperature and Rinse buttons, keys one and two, to advance or retry tests during automatic mode.
Let the sequence finish to return to diagnostic mode, or press the Power button to exit quickly back to standby.
Step 10 Check the software version
Press and hold key number two in diagnostic mode to display the software version.
Step 11 Enter the error code display
Press key number three in diagnostic mode to enter the error code system.
Look at the four lights at the top of the washer, since they flash to show stored error codes.
Step 12 Decode Whirlpool and Maytag error codes
Treat each error as a combined F code and E code that must be read from the flashing LEDs.
Read the F code when the Lid Lock light is lit, and interpret the other lit LEDs using the binary chart on the tech sheet.
Read the E code when the Lid Lock light is not lit, and interpret the lit top LEDs using the same binary chart.
Look up the decoded F and E values on the tech sheet’s error code list to identify the fault.
Step 13 Scroll through and clear stored error codes
Press key number three to cycle through stored error codes.
Press and hold key number three for five seconds to wipe all stored codes.
Confirm the wipe by watching for all LEDs to flash.
Press the Power button to exit back to standby mode.
Step 14 Run the factory calibration cycle
Run the automatic test mode if you need to purge water from under the tub, since it fills and then drains extensively.
Make sure the washer is in standby with no lights on the display.
Within eight seconds, press key one, press key two twice, press key one, and press key two twice.
Wait for the lid to lock and for all the lights to come on, then rotate the dial clockwise once.
Press keys one through six in order, and watch for lights to turn off as each key is pressed.
Open the lid after it unlocks, close it, and wait for it to relock and begin blinking through the calibration sequence for about four minutes.
Use the tech sheet together with the error-code and automatic-test results so you can narrow the fault before replacing parts or controls. If the washer will not enter diagnostics or calibration reliably, verify basic power and console behavior before going deeper into component diagnosis. Repair didn't go as planned? Ask our Answers community for help.
