How to Update a Dell Laptop Display Driver
    1. How to Update a Dell Laptop Display Driver, How to Update a Dell Laptop Display Driver: step 1, image 1 of 1
      • To start you will want to hit the Windows key and the R key at the same time to pull up the Run Window.
      Ask FixBot
    2. How to Update a Dell Laptop Display Driver: step 2, image 1 of 1
      • In the run window type "devmgmt.msc", and hit the OK button.
      Ask FixBot
    3. How to Update a Dell Laptop Display Driver: step 3, image 1 of 1
      • The device manager window will look like this. The items inside of the list may be a bit different on your computer. Find the item called "Display Adapters" and click on the arrow to the left of it that is shaped like this: >
      Ask FixBot
    4. How to Update a Dell Laptop Display Driver: step 4, image 1 of 1
      • The name of the display adapter may be different from the one on my computer. For this step we want the item that is in the spot that I have highlighted blue in the picture. Right click on it, and from the menu that appears click on the option that says "Update Driver". It should be the top option on the list.
      Ask FixBot
    5. How to Update a Dell Laptop Display Driver: step 5, image 1 of 1
      • You should see a window that looks like this pop up. Click on the option that says "Browse my computer for driver software".
      Ask FixBot
    6. How to Update a Dell Laptop Display Driver: step 6, image 1 of 1
      • The next step will look like this. Click on the option near the bottom that says "Let me pick from a list of available drivers on my computer"
      Ask FixBot
    7. How to Update a Dell Laptop Display Driver: step 7, image 1 of 1
      • The names of the items in this list may be different for your computer. If you have one named "Microsoft Basic Display Adapter" then select that one and hit next. If that one is not in the list then pick the one with the oldest date in the name.
      • Once you follow the instructions on the next step your computer's screen may go black for a moment. This is normal part of the update process, and nothing to worry about.
      Ask FixBot
    8. How to Update a Dell Laptop Display Driver: step 8, image 1 of 1
      • Once it is done updating you should see this screen, and the software will be up to date and you should not see the colored and white lines on your computer screen anymore.
      Ask FixBot
Finish Line
22 other people completed this guide.
Joshua Matzke
710 Reputation
1 Guide authored
3 Guide Comments
it didnt work, my screen didnt go black it just made a notification sound and that was it,
my screen is still flikering white
Gianna Bodner - Reply Share
It wanted come on I need help
TiA Rosa Anderson - Reply Share
Bonjour, sur YouTube le son débute avec une bonne intensité mais disparaît progressivement jusqu'à devenir inaudible. Merci de rédiger un tutoriel pour la solution.
dabo ethmane - Reply Share
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 185
All Time: 17,324
