How to Unclog Inkjet Printer Cartridges
  1. How to Unclog Inkjet Printer Cartridges, Automatically Clean Print Cartridges: step 1, image 1 of 3 How to Unclog Inkjet Printer Cartridges, Automatically Clean Print Cartridges: step 1, image 2 of 3 How to Unclog Inkjet Printer Cartridges, Automatically Clean Print Cartridges: step 1, image 3 of 3
    • The manufacturer first suggests using the built-in menu command to clean print cartridges. I access this from a menu on the printer, by selecting Menu/Tools/Clean Cartridges. Then I press the OK button on the printer.
    Ask FixBot
  2. How to Unclog Inkjet Printer Cartridges, Evaluate: step 2, image 1 of 1
    • If the automatic print cartridge cleaning was successful, the printer will print a good looking test page. If the cleaning fails, you'll get a page that looks somewhat like the mine.
    Ask FixBot
  3. How to Unclog Inkjet Printer Cartridges, Manually Clean Print Cartridges: step 3, image 1 of 2 How to Unclog Inkjet Printer Cartridges, Manually Clean Print Cartridges: step 3, image 2 of 2
    • This step is also recommended in the manufacturer's manual.
    • When automatic cleaning fails, it's time to literally take matters into your own hands by manually cleaning your print cartridges. Remove the cartridges from the printer. With a Q-tip moistened with distilled water, gently wipe the copper-colored area on the bottom of the ink cartridge, where the ink comes out.
    • Do not touch the copper colored area with your fingers. The oil on your hands can clog the ink cartridge or interfere with electrical contacts.
    • Do not use tap water. Tap water may contain minerals that will contaminate your printer cartridge.
    • Do not leave the ink cartridges out of the printer for more than 30 minutes, as this may dry out the cartridges.
    • Insert the ink cartridges back into the printer. Print another test page to see if the output quality is suitable.
    Ask FixBot
  4. How to Unclog Inkjet Printer Cartridges, Soak the Ink Cartridges: step 4, image 1 of 2 How to Unclog Inkjet Printer Cartridges, Soak the Ink Cartridges: step 4, image 2 of 2
    • When the manufacturer's recommendations fail, try mine! I have had success in soaking my ink cartridges in a shallow plastic lid with just enough distilled water to cover the bottoms.
    • Soak for 20 minutes. To make the ink cartridges stand up with their business end slightly tilted in the water, I propped them up with ballpoint pens. After the soaking, gently dry off the wet area with a Q-tip.
    • Insert the ink cartridges back into the printer. Print a test page. If you're fortunate, the print quality will be much improved.
    Ask FixBot
You’re done. Print quality should be greatly improved.
3 other people completed this guide.
gordonhamachi
4,665 Reputation
20 Guides authored
1 Guide Comment
How to remove a stuck sheet of paper
Karen Hinds - Reply Share
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 151
All Time: 8,923
