Up to 20% off select tools
How to Turn a Loop - Eye Pin Technique
Views: 3.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
167
All Time:
3,106
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 seconds - 1 minute
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide you will learn a common beading technique known as 'Turning a Loop". In this guide we will be using an eye pin.
    1. How to Turn a Loop - Eye Pin Technique, Thread and Bend: step 1, image 1 of 1
      • Thread a bead onto your eye pin.
      • Using your chain nose pliers, make a 90 degree bend just above your bead.
      Ask FixBot
    2. How to Turn a Loop - Eye Pin Technique, Remove Excess Pin Tail: step 2, image 1 of 1
      • Use side cutters to cut the wire, leaving a tail that's about one third of an inch long.
      Ask FixBot
    3. How to Turn a Loop - Eye Pin Technique, Turn the Loop: step 3, image 1 of 1
      • Position your round nose pliers at the end of the tail, making sure the tail faces away from your body. Wrap the wire towards you to create a loop.
      Ask FixBot
    4. How to Turn a Loop - Eye Pin Technique, Align Loops: step 4, image 1 of 1
      • When making a link like this you'll want both loops to face the same direction. To do this, grip each loop with a pair of chain nose pliers and just twist until your loops are where you want them.
      Ask FixBot
    5. How to Turn a Loop - Eye Pin Technique, Opening and Closing the Loop: step 5, image 1 of 1
      • To open and close the loop, you can use chain nose pliers and gently twist it open from side to side.
      Ask FixBot
Practicing these steps will help you to get the loop tight against the bead, and the loop size consistent.
2 other people completed this guide.
Author
with
Shaun Harrington
206 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 167
All Time: 3,106
