Introduction
If a Whirlpool front-load, stackable electric dryer runs but won’t heat at all, the problem is often missing 240 V power at the outlet, a failed thermal fuse, a bad heating element, or a control-board issue. This guide walks you through checking outlet voltage with a multimeter, resetting the breaker, safely opening the dryer, and testing the thermistor, thermostat, thermal fuse (thermal cutoff), and heating element. Screw locations, braces, and heater housings can vary slightly by model.
Step 2 Test outlet voltage with a multimeter
Set a multimeter to AC voltage.
Pull the plug out slightly so you can touch the meter probes to the outlet slots without fully unplugging the cord.
Measure between the middle and left slots, and confirm about 120 V AC.
Measure between the middle and right slots, and confirm about 120 V AC.
Measure between the left and right slots, and confirm about 240 V AC or something near it.
Step 3 Reset the breaker or address cord and outlet damage
If you don’t get about 240 V between the two outer slots, suspect a breaker, cord, or outlet problem.
Fully reset the breaker by turning it off, then turning it all the way back on.
Replace the power cord or the outlet if either is damaged.
Step 4 Remove the top panel
Use a nut driver to remove the two hex screws securing the top.
Pull the top panel rearward, then lift it up and out.
Step 6 Remove the user interface and disconnect its harness
Remove the two screws holding the interface to the front of the dryer.
Remove the press-mount cable tie from the front bracing.
Disconnect the harness that runs from the control board to the front interface.
Rock the interface toward the front, then lift it up.
Feed the disconnected harness through the metal bulkhead so the interface can be fully removed.
Step 7 Remove the bottom front screws
Use a 1/4" nut driver to remove the four screws securing the bottom of the dryer front.
Step 8 Remove the front panel and disconnect the door switch
Set the dryer back down, and open the door.
Remove the two large Phillips screws at the bottom of the filter housing.
Unclip the door switch wire harness.
Remove the three screws along the top of the dryer front, and remove the middle screw last.
Route the door switch harness through the bulkhead, then lift the front up and out.
Step 9 Remove the moisture sensor connector and top bracing
Disconnect the moisture sensor connector in the lower right corner of the bulkhead.
Remove the top front bracing if it blocks access on your model.
Use a 1/4" nut driver to remove the four bracing screws, including the top corner screws and the left and right front-side screws.
Lift the bracing up and out, and release any locking tabs on each side.
Step 10 Remove the blower screws and bulkhead
Remove the blower housing screw at the very bottom.
Remove the three additional screws around the blower housing if you need to separate the blower assembly from the bulkhead.
Remove the four bulkhead screws from around the edges of the bulkhead.
Lift the bulkhead up off the support arms, then pull it forward and out.
If the drum catches on the front roller wheels, rotate or slide the drum slightly to help dislodge the bulkhead.
Step 11 Remove the belt from the idler pulley and motor pulley
Locate the idler pulley behind the blower wheel area.
Pull the idler pulley to the left to relieve belt tension.
Pull the belt rearward to free it from the idler pulley, and let the pulley relax.
Move the belt up and away from the motor pulley so the drum can come out.
Step 12 Remove the drum and inspect for lint and damage
Pull up on the belt, then pull the drum toward the front of the dryer to remove it.
Inspect the inside of the cabinet for obvious damage or irregularities.
Remove any heavy lint buildup that could restrict airflow and reduce drying performance.
Step 13 Locate the heating system components
Locate the thermal fuse or thermal cutoff, the heating element, the thermostat, and the thermistor.
Inspect the wiring to these components for any burnt wires or terminals.
Step 14 Test the thermistor resistance
Remove at least one wire connector from the thermistor.
Set the multimeter to ohms or resistance.
Touch the meter probes to the thermistor terminals and read the resistance.
A good thermistor should read about 11,200 ohms at 75 °F ambient temperature.
Replace the thermistor if the reading is off by more than 10% to 15%.
Step 15 Test the heating element for continuity and shorts
Use needle-nose pliers to remove the terminal connectors from the heating element.
Measure across the two heating element spade terminals and look for about 10 ohms.
Replace the element if the meter shows OL or a very different value.
Test for a short by probing a heating element spade while probing the heater can, and check multiple spots on the can.
Replace the element if you get any resistance value during the can-to-terminal test.
Step 16 Test the thermostat
Remove the thermostat wire connectors.
Set the multimeter to ohms or resistance and test across the thermostat terminals.
A good thermostat should read 0.00 ohms.
Replace the thermostat if the meter shows OL.
Step 17 Test the thermal fuse and correct the airflow problem
Remove the two thermal fuse wires.
Test across the thermal fuse terminals with the multimeter set to ohms or continuity.
A good thermal fuse should read 0.00 ohms or make the continuity sound.
Replace the thermal fuse if the meter shows OL.
Step 18 Replace the heating element if needed
Disconnect all wires from the heating element before removing it from the heater housing.
On this style, remove the mounting screw at the front, then bend the face cover down or remove it with a hex screw.
Pull the element straight out of the housing.
Slide the replacement element back in until fully seated.
Step 19 Reinstall the drum and belt
Set the drum back into the dryer and use the belt to maneuver it into place.
Thread the belt onto the motor pulley.
Press the idler pulley to the right to apply tension to the belt.
Turn the drum by hand to confirm it spins smoothly and the blower housing moves as the drum turns.
Step 20 Reinstall the bulkhead, blower screws, and bracing
Lift the bulkhead into place and hook it onto the small support fingers at the top of the chassis if your model uses them.
Align the bulkhead rollers with the front lip of the drum, and rotate the drum while pushing if it won’t seat easily.
Use a 1/4" nut driver to install the four bulkhead corner screws.
Reinstall the blower housing screws you removed, including the bottom screw at minimum.
Reinstall the top front bracing, latch its metal fingers, and install its screws.
Step 21 Reinstall the front panel and user interface
Thread the door switch harness back through the left side of the bulkhead to the rear.
Hang the front panel in place, and align it with any small mounting fingers on the bracing.
Install the three top screws, the four bottom screws underneath, and the two Phillips screws at the filter housing.
Feed the interface wire through the front bracing, seat the interface in its slots, and install the two interface screws.
Reinstall the top panel and its two hex screws, then plug in the dryer and test for heat.
Step 22 Perform an advanced control board voltage test
Set the multimeter to AC voltage.
Probe the red wire at the terminal block and the red wire at the control board lower-right corner, and look for about 140 V AC while heating.
Probe the red and black wires on the power board, and look for under 1 V when the board is supplying voltage.
Turn the temperature down to zero, listen for the relay click, then recheck for 0 V on red-to-red and about 240 V on red-to-black at the board.
Replace the control board if these readings are far off.
If the dryer heats again after you correct the failed component and any airflow restriction, finish by cleaning lint from the vent path so the repair lasts. If the heater circuit checks good but the dryer still will not heat, move next to control-board, wiring, or power-supply diagnosis instead of swapping more parts blindly. Repair didn't go as planned? Ask our Answers community for help.
