Introduction
If the washer agitates and drains but won't spin, the built-in diagnostic mode can help narrow the fault. This guide shows how to enter diagnostics on a Samsung WA40J3000WA and how to inspect the wiring, capacitor, shift actuator, and TMR sensor that commonly stop the washer from reaching spin speed.
Step 2 Enter diagnostic mode
Plug the washer in.
Press the Power button to turn the washer on.
Press and hold the Temp button until diagnostic mode starts.
Step 3 Read and scroll stored error codes
Identify the error code by watching which indicator lights blink.
Turn the cycle dial to scroll through stored failures and faults.
Step 4 Know the limits of the code information provided
Use the blinking-light pattern you recorded to look up the code in the model’s tech manual if it isn’t covered by the checks below.
Step 5 Prepare for no-spin troubleshooting under the washer
Access the underside of the washer to reach the motor and transmission area.
Focus on the shift actuator, the capacitor, and the TMR sensor when the washer refuses to spin.
Step 6 Inspect the capacitor and its wiring
Locate the capacitor and find the blue wire and the red wire connected to it.
Gently tug the wires to confirm they aren’t loose, disconnected, or severed.
Inspect the capacitor housing for damage or bulging material coming out of the casing.
Replace the capacitor if the casing looks damaged or swollen.
Step 7 Test the shift actuator and check its wiring
Locate the shift actuator, which shifts the washer from agitate to spin.
Disconnect the Molex connector from the shift actuator.
Use a multimeter to measure the shift actuator resistance at the connector.
Confirm the reading is between 1000 and 1100 Ω.
Inspect and gently tug the small shifter wire located just above the shift actuator for damage.
Step 8 Access the TMR sensor
Locate the TMR sensor on the top side of the motor area.
Remove the large bracket to reach the TMR sensor.
Remove additional motor and transmission components as needed to get clear access to the sensor.
Step 9 Inspect the TMR sensor and harness
Identify the TMR sensor and the wire harness connected to it.
Inspect the harness and sensor terminals for a snapped or disconnected wire.
Step 10 Repair the TMR sensor wiring or replace the assembly
Remove the plastic cover piece by removing the two screws that hold it in place.
Repair a snapped wire by soldering the wire back onto the TMR sensor terminal.
Disconnect the Molex harness if needed to make the soldering repair easier.
Replace the entire shifting assembly if you can’t solder, because Samsung doesn’t sell the TMR sensor by itself.
Step 11 Reassemble and confirm the spin function
Reinstall the plastic cover, the bracket, and any motor or transmission components you removed.
Plug the washer in and run a test to confirm it spins normally.
Reassemble the washer and confirm it completes a full spin before returning it to service. Repair didn't go as planned? Ask our Answers community for help.
