Introduction
If a Midea-built top-load washing machine won’t spin at all, or spins but leaves clothes too wet, the cause is often something simple like leveling, or a failed sensor or drive component. This guide walks through checks that apply to Midea sub-brands like Criterion, Frigidaire, and Insignia, including impact switch testing, washplate and tub checks, belt and clutch inspection, and shift actuator electrical testing.
Step 2 Use error codes to pick where to start
If the washer shows an E5 code, focus on the impact switch checks in this guide.
If the washer shows an E4 out-of-balance code, start with leveling and tub and washplate inspections.
If the washer shows an FD lid lock error code, diagnose the lid lock system before chasing spin problems.
Step 3 Level the washer
Place a bubble level on the washer, and check that it sits level on the floor.
Adjust the feet under the washer by turning them with a wrench or by hand until the washer is level.
Step 4 Open the control console top
Use a Phillips screwdriver to remove the three screws at the rear of the top cover.
Remove the right screw, the left screw, and the middle screw between the inlet valves.
Roll the washer console top forward to access the components under it.
Step 5 Remove the impact switch
Locate the impact switch on the right side under the console on this model.
Use a Phillips screwdriver to remove the two screws securing the impact switch.
Lift the impact switch out so you can inspect it.
Step 6 Inspect and test the impact switch
Inspect the impact switch and make sure it can pivot freely.
Use needle-nose pliers to pull the wires off the switch terminals.
Set a multimeter to resistance mode in ohms.
Touch a meter lead to each switch prong, then press the switch in while watching the meter.
Replace the impact switch if the reading doesn’t change when the switch is pressed.
Step 7 Reinstall and verify impact switch alignment
Slot the impact switch back into position, and reinstall its two mounting screws.
Correct any tub position issue that jams the switch, because it can contribute to an E5 code and poor spinning.
Step 8 Close the console
Roll the console back into place, and pivot the small tabs so the top locks into position.
Reinstall the three rear Phillips screws that secure the top cover.
Step 9 Inspect the tub and washplate for looseness or damage
Push the tub side-to-side to check for wobble or play that could cause bouncing and poor spinning.
Use a very thin flathead screwdriver to lift out the small center cap on the washplate.
Remove the center bolt or screw holding the washplate, which may be a 10 mm bolt on agitator models or a Phillips screw on some models.
Pull the washplate up and out, using a puller-style tool if needed, since it may be stuck by buildup.
Inspect the bolts and the washplate housing under the plate, and tighten any loose bolts with a 10 mm tool.
Replace the washplate if its threads or underside are stripped or damaged.
Step 10 Set up to access the underside
Tilt the washer onto its side to about 90 degrees so you can access the bottom and the rear plate area.
Step 11 Inspect the belt and lower cover
Inspect the belt drive area for obstructions or belt damage that could prevent full-speed operation.
Remove the lower cover plate screws if you need a clearer view of the transmission and clutch system.
Step 12 Check the shifter linkage and clutch arm movement
Inspect the shift actuator area and reattach the small wire to the transmission if it has been knocked loose.
Make sure the plastic clutch arm can move freely so the transmission can engage spin.
Step 13 Remove and test the shift actuator
Use a 10 mm socket wrench or a Phillips screwdriver to remove the two screws holding the shift actuator.
Trace the actuator wiring into the wire cluster bag, and disconnect the actuator harness from the cluster.
Set a multimeter to resistance mode, and use the 200 to 2000 ohm range if the meter is not auto-ranging.
Press the meter leads into the actuator harness terminals and measure resistance, which should be about 1500 ohms ± 10%.
Replace the shift actuator if the reading is far outside the expected range.
Step 14 Reinstall the shift actuator and wiring
Reconnect the actuator harness into the wire cluster and route it the same way it was originally.
Mount the wire bag back onto the side of the washer using its metal wire tie.
Slide the wire retainer into the transmission shifter, then seat the actuator into the correct hole position.
Reinstall the two 10 mm screws securing the actuator.
Step 15 Decide whether the control board or wiring is the likely cause
Inspect wiring you handled for damage, since a broken wire can also cause spin problems.
Reconnect any wire ties and covers you removed, lower the washer back onto the floor carefully, and confirm the drain hose is properly placed before restoring power. If the washer spins but still doesn’t spin-dry fully, recheck leveling, load balance, and any tub looseness that could trigger out-of-balance behavior. Repair didn't go as planned? Ask our Answers community for help.
