How to Troubleshoot a GE Washing Machine Not Draining
Video Guide
This guide was transcribed from a YouTube video.
    • Place a bucket on the floor beside the drain hose outlet.
    • Lower the drain hose so its end is near floor level to let water siphon into the bucket.
    • The siphon process can be slow but will remove most of the water without tools.
    • Check the entire drain hose for twists, kinks, or physical damage.
    • Ensure the hose is inserted only a few inches into the standpipe and not against a 45-degree elbow.
    • Confirm the hose exit point is at least 30 inches above the floor to prevent siphoning.
    • Unplug the washer before moving it.
    • Tilt the appliance and look under or behind the cabinet for a plastic pouch holding the hidden technician’s manual and schematic.
    • Use a quarter inch nut driver to remove the two screws securing the rear metal cover.
    • Slide the cover to the right then pull it away to expose the console back.
    • Detach the cardboard or plastic flap to reveal the control board area.
    • Locate the gray pressure hose connected to the control board.
    • Check the hose for kinks, cracks, or disconnection from its port.
    • Re-seat the hose firmly if it was loose.
    • Refer to the schematic to locate the drain pump terminals on the control board.
    • In the GTW465ASN, the drain pump leads are white and purple.
    • Set the multimeter to ohms and unplug the harness that contains the pump wires.
    • Insert the meter probes into the white and purple terminals to read resistance.
    • A healthy pump circuit should measure about 13 ohms; a reading of open or zero indicates a failed pump or broken wire.
    • Reconnect the harness, then energize the washer only after tests are ready.
    • High voltage is present; wear rubber gloves and avoid touching metal while measuring.
    • Set the multimeter to AC volts and back-probe the white and purple pump terminals.
    • Turn the cycle selector to Drain & Spin and press Start, or enter forced drain by holding Start, rotating seven clicks, releasing, then turning eight clicks counter-clockwise.
    • A steady 118–125 VAC confirms the board is commanding the pump; zero volts indicates a faulty board.
    • Hold Start for three seconds to cancel the test and disconnect power.
    • Rock the plastic console down into position and tap it forward to lock.
    • Slide the metal cover back into place and secure the two quarter-inch screws.
    • Lay a sturdy box or block behind the washer and tip the appliance gently onto its back.
    • Keep the drain hose above tub level to prevent any remaining water from spilling.
    • Tape or secure the lid to prevent it from falling open while the unit is on its back.
    • Use a three-eighths socket wrench to remove the three screws holding the plastic belt cover.
    • Note the position of any grounding strap attached to one of the screws for correct reassembly.
    • Locate the drain pump harness near the pump housing and verify it is firmly seated.
    • If the harness was loose, reconnect it before deeper repairs.
    • Disconnect the pump wire harness and cut the cable tie securing it if necessary.
    • Compress the spring clamp with slip joint pliers and slide the drain hose off the pump.
    • Remove the three three-eighths screws that mount the pump to the base.
    • Lift the pump straight out of the washer.
    • Check the opening between the tub and pump housing for coins, lint, or other debris.
    • Inspect the black hose from pump to standpipe for clogs.
    • Remove any obstruction found.
    • Remove the five Phillips screws on the gray side of the pump and separate the two halves.
    • Clear any debris found inside the pump chamber.
    • Rotate the impeller by hand; it should show strong magnetic resistance in several positions then spring forward.
    • Lack of resistance or damaged blades indicates a failed pump requiring replacement.
    • The GTW465ASN uses a pump with an integrated wiring harness, so a faulty pump must be replaced as a complete assembly.
    • Position the pump correctly on the base and install the three mounting screws.
    • Reattach the drain hose and release the spring clamp into its groove.
    • Plug the wire harness fully and secure it with a new cable tie if supplied.
    • Align the belt cover and install its three screws with the three-eighths socket wrench.
    • Reattach the grounding strap under the bottom screw in its original position.
    • Stand the washer upright, reconnect hoses, and restore power.
    • Run a Drain & Spin cycle to verify that water is expelled and the pump operates quietly.
    • If the unit still fails to drain, inspect the wire harness for hidden damage along its route.
Your GE washer should now drain and spin without error. Regularly check the hose height and keep pocket debris out of the tub to prevent future clogs. If problems return, revisit the schematic and re-test the circuit before ordering parts.
Ben Schlichter
6,539 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 40
All Time: 201
