How to Troubleshoot Drainage Issues in a Washing Machine
Video Guide
This guide was transcribed from a YouTube video.
      • Switch off the washing machine at the power supply and unplug it.
      • Turn the cold water inlet tap 90 degrees to shut off the water supply.
      • Close the main stopcock if you can't find a tap on the washing machine inlet hose.
      • Only isolate the water in the street if it is safe, permitted, and won't shut off water to other homes.
      • Wear waterproof gloves when handling stagnant water, sludge, or sharp debris.
      • Remove wet clothes, open the door carefully, and use a sponge and towel to remove as much water from the drum as possible.
      Ask FixBot
      • Find the filter or coin catcher access flap near the bottom of the washing machine.
      • Most filters are on the bottom right, but some models place them on the bottom left.
      • Place a towel on the floor and keep a shallow tray and sponge ready.
      • Some washers have a small drain hose beside the filter, and some drain only through the filter opening.
      Ask FixBot
      • Pull out the small drain hose if the washer has one.
      • Place the hose end into a shallow tray or bucket.
      • Remove the hose cap or nozzle and let the water drain.
      • Empty the tray as needed until water stops flowing.
      • Stagnant washer water may smell bad, especially if it has been trapped for a while.
      • Refit the hose cap and clip the hose back into its holder.
      • Don't push the hose so far back that it disappears into the washing machine.
      Ask FixBot
      • Place the towel and shallow tray directly under the filter opening.
      • Turn the filter anti-clockwise only enough to let water drain into the tray.
      • Do not remove the filter completely while water is still pouring out.
      • Tighten the filter between tray empties if needed.
      • Repeat the drain-and-empty process three or four times, or until the flow slows.
      • Expect more water and stronger smells if the washer didn't have a small drain hose.
      Ask FixBot
      • Remove the filter completely after the water has drained.
      • If the filter catches, tighten it slightly, then loosen it again to work the debris loose.
      • Use pliers gently on the filter cap only if it remains stuck.
      • The filter is plastic, so don't force it or crush the cap with the pliers.
      Ask FixBot
      • Look inside the filter and remove anything blocking it.
      • Common blockages include broken hair clips, coins, hair bands, face masks, and colour catchers.
      • A blocked filter can stop water from draining out of the washing machine.
      Ask FixBot
      • Scrub the filter with an brush and hot, soapy water.
      • Remove long hair, dirt, debris, and mold from the filter.
      • Clean the filter until the openings are clear and the threads are free of grime.
      Ask FixBot
      • Look into the opening behind the filter and find the pump impeller.
      • Clean the impeller area with the brush and hot, soapy water.
      • Make sure nothing is blocking the impeller and that no debris is sitting at the back.
      • Rotate the impeller gently to confirm it spins freely.
      • Remove hair bands, metal hair clips, or other items wrapped around the impeller.
      • Use pliers for sharp metal debris instead of pulling it with your fingers.
      Ask FixBot
      • Line up the clean filter and turn it clockwise to lock it in place.
      • The filter should thread in easily and tighten near the end.
      • Remove the filter and line it up again if it doesn't turn smoothly.
      • Don't force the plastic threads.
      • Refit the filter access cover flap.
      Ask FixBot
      • Plug the washing machine back in and switch it on.
      • Turn the cold water supply back on.
      • Open the main stopcock fully, then turn it back about 45 to 90 degrees to help prevent it from jamming.
      • Add washing machine cleaner directly to the empty drum.
      • Run a drum clean program or the hottest empty wash available, such as 90 °C.
      • Check whether the washer drains correctly at the end of the cycle.
      • No more drainage work is needed if the washer drains normally.
      Ask FixBot
      • Check the household drain pipework if the washing machine still doesn't drain correctly.
      • Look for a drain hose that goes into pipework behind the washer or into a connection under the sink.
      • Pull the washer out only far enough to reach the back if it uses wall pipework.
      • Don't pull the washer too far because the cold water feed and drain hose may still be attached.
      • Keep a towel, shallow tray, and bucket ready for dirty water.
      Ask FixBot
      • Gently pull the washer drain hose out of the wall drain pipe.
      • Put the hose end into a bucket and wipe grime from the hose.
      • Inspect the wall drain pipe for blockages.
      • Use a mobile phone with the light on to record inside the pipe, then review the footage.
      • Sludge and residue often collect in the U-bend, which catches debris and helps stop smells entering the kitchen.
      Ask FixBot
      • Undo the threaded fittings and remove the U-bend if the fittings aren't glued.
      • Use a towel or shallow tray to catch water from the pipework.
      • Check the U-bend for sludge, residue, and blockages.
      • Put sludge in the rubbish instead of pouring it down the sink.
      • Reinstall the U-bend and tighten the threaded fittings.
      • Push the washer drain hose back into the wall drain pipe.
      • Forgetting the hose can flood the floor during the next wash.
      • Call a plumber if the fittings are glued, damaged, or won't come apart safely.
      Ask FixBot
      • Find the washing machine drain hose connection under the sink.
      • Remove any tape or metal clip holding the hose in place.
      • Hold the hose over a bucket or shallow tray to drain excess water.
      • Clean the hose end and the connection point until they are clear.
      • Refit the hose and secure it with the metal clip.
      Ask FixBot
      • Unscrew the two U-bend fittings under the sink and remove the U-bend.
      • Check the U-bend for sludge and blockages.
      • Clean the U-bend until it is clear.
      • Reinstall the U-bend and tighten the fittings.
      Ask FixBot
      • Plug the washing machine back in and switch it on if it is still unplugged.
      • Confirm the washer drains properly at the end of the cycle.
      Ask FixBot
      • Check the outside drainage if you can safely access it.
      • Leave the dispenser drawer and drum door slightly ajar after washes to improve ventilation and reduce smells and mold.
      • If the washer still won't drain, inspect manhole covers and external drainage only if it is safe and permitted.
      • Call a drainage company or plumber if you can't check the external drainage yourself.
      • If the household drains are clear, the washing machine pump may be faulty.
      • Call an appliance engineer, or consider replacing the washing machine if it is old and uneconomical to repair.
      Ask FixBot
If the washer drains normally after a filter, impeller, hose, or pipework clean, keep the door and dispenser drawer slightly open between washes to reduce smells and mould. If the problem returns or the pump is suspected, get help from a qualified appliance engineer, plumber, or drainage company. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 105
All Time: 241
