How to Tie a Tie: Pratt
  1. How to Tie a Tie: Pratt, Preparation: step 1, image 1 of 1
    • Fold the collar of your shirt up.
    Ask FixBot
  2. How to Tie a Tie: Pratt: step 2, image 1 of 1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: the narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
    Ask FixBot
  3. How to Tie a Tie: Pratt, Tying: step 3, image 1 of 1
    • Take the active end and cross it under the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
    Ask FixBot
  4. How to Tie a Tie: Pratt: step 4, image 1 of 1
    • Lift the active end up, so that it is now pointing up.
    Ask FixBot
  5. How to Tie a Tie: Pratt: step 5, image 1 of 2 How to Tie a Tie: Pratt: step 5, image 2 of 2
    • Pull the active end down through the loop around your neck, so that it is now pointing down and to the left.
    Ask FixBot
  6. How to Tie a Tie: Pratt: step 6, image 1 of 1
    • Cross the active end over the front of the knot, so that it is now pointing to the right.
    • Note: leave this wrap a little loose, as it will be used in step 8.
    Ask FixBot
  7. How to Tie a Tie: Pratt: step 7, image 1 of 1
    • Pull the active end up through the neck loop, so that it is now pointing up.
    Ask FixBot
  8. How to Tie a Tie: Pratt: step 8, image 1 of 2 How to Tie a Tie: Pratt: step 8, image 2 of 2
    • Pull the active end down through the wrap you created in step 6 (see second picture).
    Ask FixBot
  9. How to Tie a Tie: Pratt, Finishing: step 9, image 1 of 1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
    Ask FixBot
  10. How to Tie a Tie: Pratt: step 10, image 1 of 1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
    Ask FixBot
  11. How to Tie a Tie: Pratt: step 11, image 1 of 1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
    Ask FixBot
Congratulations! You've successfully tied the Pratt knot!
3 other people completed this guide.
Wes
535 Reputation
2 Guides authored
The Electric Warthogs Member of The Electric Warthogs
Community
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 66
All Time: 1,282
