Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓An engine coolant temperature (ECT) sensor can pass a resistance test on the bench and still send the wrong temperature to the engine computer once it is plugged in. The module reads the voltage of the whole circuit, sensor and wiring together, so corroded terminals, resistance in the wiring and leakage inside the connector all change the value it sees [1].
So the order matters: scan data first, the connected signal voltage second, the connector and wiring next, and the sensor itself last. The bench test comes last because it is the only step that cannot see the wiring.
The voltage and resistance figures quoted in the steps are the ones a manufacturer (Mitsubishi) publishes for one of its circuits, used here as an example of how a specification reads. Your engine has its own table: take the pass/fail numbers from the service information for your part number.
Work down this list and stop when a step points somewhere specific: 1. scan data after a cold soak, 2. the connected signal voltage while the engine warms, 3. the reference feed, connector and wiring, 4. the sensor on the bench.
After the car has stood overnight, plug in a scan tool that shows live data and compare the coolant temperature with the intake air temperature before starting the engine.
Coolant, engine metal and intake air should all be near the same ambient temperature, so the two readings should sit close together.
The sensor is a thermistor whose resistance falls as it warms. The module feeds it 5 volts through a resistor inside the module and reads the voltage left on the signal wire. It never measures resistance directly.
Extra resistance in series (a corroded terminal, a damaged wire) makes the circuit look colder than the coolant really is.
A leakage path to ground (coolant or corrosion inside the connector) makes it look hotter.
With the sensor still plugged in, slide a backprobe pin into the signal terminal from the wire side of the connector and connect the meter (DC volts) between the pin and a good ground.
Start the engine and watch the voltage fall as the coolant warms. On the Mitsubishi circuit used as the example, the published values are about 2.3 to 2.9 V at 20 °C falling to 0.3 to 0.9 V at 80 °C.
The voltage should fall smoothly. A value that freezes, jumps or moves in steps is the fault.
Unplug the sensor, switch the ignition on, and measure at the harness-side connector. The example procedure expects 4.5 to 4.9 V on the signal terminal. A missing or low feed sends you to the circuit rather than the part.
Inspect the connector: green or white crust on the terminals, a spread female terminal, or coolant residue inside the housing all change what the module reads. Wiggle the connector and the harness while watching live data; an intermittent fault shows up under movement.
With the ignition off and the module connector released as the service information directs, check continuity from each sensor terminal to its module pin, and check each wire to ground for a short.
Only once the circuit has been cleared, let the engine cool completely, drain coolant to below the sensor and remove the sensor (see the next steps).
Short the meter leads together first and note the lead resistance; subtract it from the readings. It matters most at the hot end, where the sensor's resistance is low.
Immerse the sensing tip in a container of water with a thermometer in the same water. Stir, and read the thermometer and the meter at the same moment. Repeat at a second temperature (for example room temperature and hot tap water).
Compare both readings with the published values for that exact part number. Figures differ widely between sensors (roughly 2,000 to 10,000 ohms at room temperature across common parts), so a chart from a different engine proves nothing.
Drain the coolant to below the level of the sensor. Catch what comes out, keep it off belts and pulleys, and plan to refill with the coolant type and mix specified for the vehicle.
Disconnect the battery if the procedure calls for it. Find the connector's lock tab before pulling, and support the harness rather than the connector body.
Use a deep socket or the specified sensor wrench on the hex, positioned so the tool never touches the connector body.
Compare old and new before fitting: thread pitch, reach, hex size, connector keying, the sealing method and the resistance curve all have to match. Two sensors that fit the same hole can carry different torque figures and different sealing.
Seal it the way the part is designed to seal. A part that seals on an O-ring or a supplied washer gets no thread sealant; a part that specifies a named thread sealant gets that sealant. A crush washer is not reused.
Torque to the published figure for that part number. Published figures for parts that fit the same thread range from about 18 to 30 N·m, so take yours from the service information, not from a sensor that looks the same.
Refill with the specified coolant and follow the bleed procedure for the vehicle. Air trapped around the sensing tip isolates it from circulating coolant and distorts the reading.
Run the engine to operating temperature and watch the scan-tool value climb smoothly. Check for leaks at the sensor once the system is up to pressure.
Clear the fault codes and confirm none return after a full warm-up and a drive.
A sensor that passes the connected-signal test and tracks its published curve at two temperatures is good; a wrong reading with a good sensor is in the connector, the wiring or the module feed. Replace the sensor only when the bench test fails, and fit the replacement with the sealing method and torque published for that part.
