Up to 20% off select tools
How to Test a Car Battery With a Multimeter
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
85
All Time:
137
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
A digital multimeter turns "maybe the battery is dying" into a number. Three readings, taken in order, separate a weak battery from a charging-system fault: the voltage of the rested battery, the voltage while the engine cranks, and the voltage with the engine running.
The most common mistake is testing right after a drive. A recent drive or charge leaves a surface charge that makes a weak battery look full, so the battery has to rest first [1].
The thresholds below are the commonly published figures for a 12 V lead-acid battery at about 20 °C (70 °F). Cold lowers the readings slightly and AGM batteries can read a little higher, so check the battery maker's chart for exact numbers.
      • Work in a ventilated place, wear safety glasses, and take off rings and metal watch straps.
      • A lead-acid battery vents hydrogen. Keep sparks, flames and cigarettes away, and never lay a tool across the two posts.
      • Do not test a battery that is cracked, leaking, swollen or frozen. Replace it.
      • For a true resting reading, leave the car switched off for a few hours. If it was just driven, switch the headlights on for one minute and off again to burn off the surface charge, then wait a few minutes.
      Ask FixBot
    1. How to Test a Car Battery With a Multimeter, Set the meter to DC volts: step 2, image 1 of 1
      • Plug the black lead into the COM socket and the red lead into the V socket.
      • Turn the dial to DC volts. The symbol is a V with a straight line (sometimes a dashed line under it), not the wavy line of AC volts.
      • On a manual-range meter choose the 20 V range. An auto-ranging meter needs no range.
      Ask FixBot
    2. How to Test a Car Battery With a Multimeter, Read the resting voltage: step 3, image 1 of 1
      • Touch the red probe to the positive (+) post and the black probe to the negative (-) post. Press firmly on bare metal, not on the corrosion crust.
      • 12.6 to 12.8 V: fully charged. 12.4 V: about 75 percent. 12.2 V: about 50 percent. Below 12.0 V: discharged.
      • Below about 12.4 V, recharge the battery fully, let it rest, and test again before judging it.
      • Above about 12.9 V usually means surface charge from a recent drive or charger. Rest the battery and test again.
      • Reversed probes only show a minus sign in front of the reading. Nothing is harmed.
      Ask FixBot
    3. How to Test a Car Battery With a Multimeter, Cranking test: step 4, image 1 of 1
      • Keep the probes on the posts and have a helper crank the engine. Watch for the lowest number while the starter turns.
      • A healthy battery stays above about 9.6 V while cranking at room temperature.
      • A dip toward 8 V or lower points to a weak battery or a high-current fault in the starting circuit, even if the resting voltage looked fine.
      • Cold weather lowers the cranking reading a little. Judge a marginal result against the battery maker's figures.
      Ask FixBot
    4. How to Test a Car Battery With a Multimeter, Charging test: step 5, image 1 of 1
      • With the engine running at idle, read the posts again.
      • 13.7 to 14.7 V means the alternator is charging normally.
      • A reading close to the resting voltage means the alternator is not charging: check the drive belt, the alternator fuse and the wiring before blaming the battery.
      • Above about 15 V means the voltage regulator is overcharging, which cooks the battery. Have the alternator checked.
      • Keep hands, leads and clothing clear of the belt and fan while the engine runs.
      Ask FixBot
      • Low resting voltage that also collapses while cranking: the battery.
      • Healthy resting voltage but low voltage with the engine running: the alternator or its wiring.
      • Erratic or jumping readings: clean the posts and clamps, tighten them, and test again.
      • Voltage shows the state of charge, not the remaining capacity. A battery can read 12.6 V and still fail under load, so have a borderline battery load-tested (many parts stores do this free) before replacing it.
      • A battery that tests well but is flat again after a night parked: look for a parasitic draw rather than buying a new battery.
      Ask FixBot
Recharge and retest a battery that reads low. Replace one that will not hold 12.6 V after a full charge, or that drops below about 9.6 V while cranking. If the charging voltage is outside 13.7 to 14.7 V, the alternator circuit is the next thing to check.
John Albert
1 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 85
All Time: 137
