How to Take Awesome Smartphone Photos
  1. How to Take Awesome Smartphone Photos, How to Take Awesome Smartphone Photos: step 1, image 1 of 2 How to Take Awesome Smartphone Photos, How to Take Awesome Smartphone Photos: step 1, image 2 of 2
    • Keep the subject in focus. It's easy to accidentally focus on your hand instead of the device you're working on.
    • For most smartphones, you have to tap the area on your screen where you want it to focus.
    • Use a self-timer. Believe it or not, just having your shaky hands on the phone can introduce a little blurriness into the shot. Set your camera to a short delay using the self-timer setting so that you can remove your hands completely after pressing the shutter button.
    Ask FixBot
  2. How to Take Awesome Smartphone Photos: step 2, image 1 of 2 How to Take Awesome Smartphone Photos: step 2, image 2 of 2
    • Prepare your images for a 4:3 aspect ratio. Aspect ratios may vary from phone to phone, so keep this in mind as you're snapping away. You can always photograph a wider area than necessary and crop it later in iFixit's media manager.
    • iPhones capture images in a 4:3 aspect ratio, while most Android smartphones shoot in 16:9. Become familiar with the aspect ratio of your particular phone before shooting.
    • Shoot your images in landscape orientation. It may be tempting, but don't rotate the camera to take portrait shots. For layout consistency, we require all photos to have a landscape 4:3 aspect ratio.
    • If you upload a portrait-orientation photo to iFixit, it will force you to crop it as a 4:3 landscape photo, and you will end up losing a lot of your image.
    Ask FixBot
  3. How to Take Awesome Smartphone Photos: step 3, image 1 of 2 How to Take Awesome Smartphone Photos: step 3, image 2 of 2
    • Avoid using the zoom. Unlike most cameras which use optical zoom, smartphones use digital zoom, which reduces the resolution of your image. Instead of using the zoom, simply move your phone as close as possible to the subject.
    • Avoid cropping images in your phone. Similar to using digital zoom, cropping in your phone reduces the resolution—and quality—of your photo. If you absolutely need to do some cropping, upload your original high resolution images to iFixit, and crop using our media manager.
    • The first image was taken with the camera's zoom and then cropped in the phone. This reduces the resolution and produces a grainy—or noisy—image. You can especially see this when you look at the image full-size.
    • The second image was taken with the phone as close to the subject as possible and cropped in iFixit's media manager.
    Ask FixBot
  4. How to Take Awesome Smartphone Photos: step 4, image 1 of 2 How to Take Awesome Smartphone Photos: step 4, image 2 of 2
    • Don’t use flash! Flash is the enemy—it creates harsh shadows and unseemly glares, which can result in an improperly exposed photo.
    • The first image was taken with the flash on. The edges of the photo are dark, and there is a harsh shadow behind the hand.
    • The second image was taken without the flash. There are no rigid shadows, and the background remains well-lit without falling into the shadows at the edges.
    • If you find yourself needing to use the flash, it's a good sign that you need to add more lighting to your setup.
    Ask FixBot
  5. How to Take Awesome Smartphone Photos: step 5, image 1 of 2 How to Take Awesome Smartphone Photos: step 5, image 2 of 2
    • Use your hands/tools in each shot to demonstrate the action being performed.
    • Shoot in a first-person perspective. Try to set up each shot so that it matches what your readers will see.
    • This first image isn't necessarily bad; the photo is well-lit, free of clutter, and the required action is clear—but the image isn't from the user's perspective.
    • The second image does all of that equally well and also matches what the reader is likely to see.
    Ask FixBot
  6. How to Take Awesome Smartphone Photos: step 6, image 1 of 2 How to Take Awesome Smartphone Photos: step 6, image 2 of 2
    • Keep the action in the center. Draw attention to the required procedure by centering it in the frame.
    • It's okay to show a little less of the device in order to center the action; just be sure that it is clear what part of the device you are working on.
    Ask FixBot
  7. How to Take Awesome Smartphone Photos: step 7, image 1 of 1
    • Do not take "Ta-Da!" photos. When writing instructions, it's important to be concise. A photo of a disassembled device doesn't convey any action or procedure.
    • Layout shots like this are only used on teardowns. Teardowns provide a fun first look at a device's hardware, but they are not intended to be used as instructions.
    Ask FixBot
Finish Line
40 other people completed this guide.
Kristen Gismondi
107,806 Reputation
270 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 129
All Time: 6,329
