Up to 20% off select tools
How to Splice Wire
Views: 38K
View statistics:
Past 24 Hours:
50
Past 7 Days:
395
Past 30 Days:
1,766
All Time:
37,662
Comments: 2
2 comments on steps.
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
How to Splice Wire
Parts
Tools
Introduction
Go to step 1 ↓
The purpose of this guide is to instruct users on how to effectively repair a broken wire, as they commonly become damaged. This guide will cover how to repair stranded wire and solid-core (single strand) wire.
Note: to efficiently complete the following guide, it's crucial to know how to strip wires. The following link can be used as a guide for wire stripping before continuing.
Stripping Wire: Wire Stripping
    1. How to Splice Wire, Prepare your work area: step 1, image 1 of 2 How to Splice Wire, Prepare your work area: step 1, image 2 of 2
      • Set your tools down on a clean, non-flammable surface.
      • Ensure that the work area is well-ventilated and clear of anything that can be damaged during soldering.
      • Attach a stripped wire end to each of the helping hands clips, facing the ends towards each other.
      Ask FixBot
    2. How to Splice Wire: step 2, image 1 of 1
      • Cut a piece of heat-shrink tubing such that it's 10-15 mm longer than one of the exposed wire ends.
      • Slip the heat shrink over one of the wires, making sure to move the heat shrink away from the soldering point as to avoid any burning.
      Ask FixBot
    3. How to Splice Wire, Intermesh the wire strands: step 3, image 1 of 3 How to Splice Wire, Intermesh the wire strands: step 3, image 2 of 3 How to Splice Wire, Intermesh the wire strands: step 3, image 3 of 3
      • This step shows how to physically intermesh stranded wires together. This improves the physical properties of the joined wires.
      • Unravel all of the wire strands for both the wires, intermesh them, and then twist the strands together.
      Ask FixBot
    4. How to Splice Wire, Heat up the wires: step 4, image 1 of 1
      Tool used on this step:
      FixHub Smart Soldering Iron
      $79.95
      Buy
      • Place the tip of a soldering iron against the exposed wires. You want to heat the wires hot enough such that they'll readily melt the solder.
      • Position the tip such that you maximize the wire surface area it touches.
      Ask FixBot
    5. How to Splice Wire, Apply solder wire: step 5, image 1 of 2 How to Splice Wire, Apply solder wire: step 5, image 2 of 2
      • Slowly feed solder wire into the heated wire. The wire strands should readily absorb the molten solder.
      • If the solder pools on top of the wire strands, the strands aren't hot enough to melt the solder. Try moving the soldering iron so that the tip touches more of the strands.
      • Feed solder wire along the exposed wire until everything is thinly coated.
      • Once the molten solder saturates the wire strands, allow the solder joint to cool down and solidify (2-3 minutes).
      Ask FixBot
    6. How to Splice Wire, Cover the exposed solder joint: step 6, image 1 of 3 How to Splice Wire, Cover the exposed solder joint: step 6, image 2 of 3 How to Splice Wire, Cover the exposed solder joint: step 6, image 3 of 3
      • Slide the heat-shrink over the exposed solder joint so that it completely covers the joint and the surrounding insulation.
      • The heat-shrink acts as insulation for the wire.
      • Wave a heat source (lighter or heat gun) over the heat-shrink material to activate it. Apply heat until the heat-shrink has shrunk securely around the solder joint.
      Ask FixBot
You have successfully soldered two wires together!
For more soldering tips and guides, click here.
27 other people completed this guide.
Author
with
Justin N/A Nguyen
385 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 50
Past 7 Days: 395
Past 30 Days: 1,766
All Time: 37,662
