Introduction
The purpose of this repair is to explain how to shrink the size of a tennis racket grip. This process should shrink your grip about half of one size. In other words, if you use a 4 4/8ths grip, it should be halfway between that size and 4 3/8ths.
To complete this task, you will need your tennis racket, something sharp enough to remove any original, replacement or overgrip(s) currently on your racket, and an overgrip.
If your racket does not have an overgrip on it, then skip this step.
Attach the smaller end of the new overgrip to the bottom of the handle.
Wrap the overgrip around the handle, parallel to the bottom of the grip.
Pull the grip tightly, leaving little to no open areas between the different parts of the overgrip.
Leave a little overlap between each row of your grip.
If you decide that you want to go back to the racket grip's original size, then you need to remove the overgrip and put on a replacement grip.
