How to Shorten a Sweatshirt Using the Original Hem
  1. How to Shorten a Sweatshirt Using the Original Hem, How to Shorten a Sweatshirt Using the Original Hem: step 1, image 1 of 1
    • Lay your crewneck on a flat surface.
    Ask FixBot
  2. How to Shorten a Sweatshirt Using the Original Hem: step 2, image 1 of 2 How to Shorten a Sweatshirt Using the Original Hem: step 2, image 2 of 2
    • Find your new desired length and mark it with chalk.
    • Using your chalk mark, use a ruler to mark across the width of your crewneck.
    Ask FixBot
  3. How to Shorten a Sweatshirt Using the Original Hem: step 3, image 1 of 1
    • Measure one inch below your desired length and mark using chalk.
    Ask FixBot
  4. How to Shorten a Sweatshirt Using the Original Hem: step 4, image 1 of 2 How to Shorten a Sweatshirt Using the Original Hem: step 4, image 2 of 2
    • Cut along your newly marked line.
    • Make sure to cut one layer at a time to ensure a clean cut.
    Ask FixBot
  5. How to Shorten a Sweatshirt Using the Original Hem: step 5, image 1 of 1
    • Using a ruler, mark 1/2 an inch up from the hem of your crewneck.
    Ask FixBot
  6. How to Shorten a Sweatshirt Using the Original Hem: step 6, image 1 of 1
    Ask FixBot
  7. How to Shorten a Sweatshirt Using the Original Hem: step 7, image 1 of 1
    • Flip the hem inside out and align with the cut edge of your crewneck.
    • Make sure the pieces are "good side" to "good side" by ensuring the seams are facing outward.
    Ask FixBot
  8. How to Shorten a Sweatshirt Using the Original Hem: step 8, image 1 of 1
    • Pin both pieces together with all pins facing perpendicularly to the lines you marked.
    Ask FixBot
  9. How to Shorten a Sweatshirt Using the Original Hem: step 9, image 1 of 2 How to Shorten a Sweatshirt Using the Original Hem: step 9, image 2 of 2
    • Sew one inch away from the edge, removing the pins as you go.
    • This step can also be done by hand with thread and a needle.
    Ask FixBot
  10. How to Shorten a Sweatshirt Using the Original Hem: step 10, image 1 of 2 How to Shorten a Sweatshirt Using the Original Hem: step 10, image 2 of 2
    • Flip the hem right side out and admire your creation!
    Ask FixBot
Finish Line
Izzy DeLaGarza
181 Reputation
1 Guide authored
UC Davis, Team 4-8, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 4-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G8
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 33
Past 30 Days: 164
All Time: 2,827
