How to Run Diagnostics and Recalibrate an Amana Washing Machine
Video Guide
This guide was transcribed from a YouTube video.
    • Remove the harness plate screw and the two top screws on the rear panel with a quarter inch hex head screwdriver.
    • Pull the lid toward you, lift it up, then push it back so the top pivots on the rear hinge tabs.
    • Tape the lid shut before lifting to stop it from snapping open unexpectedly.
    • Place a support behind the washer if it is not against a wall to hold the raised top securely.
    • Lift the taped lid and locate the folded technician’s service sheet on the front left corner under the top panel.
    • Remove the sheet and keep it nearby for model-specific code definitions.
    • With the washer plugged in, rotate the cycle selector counterclockwise until it is at the 12 o’clock position after one full turn.
    • Confirm all indicator lamps are off before starting diagnostics.
    • Turn the dial right three clicks, left one click, then right one click, pausing about half a second between moves.
    • Verify successful entry when all green lights flash together.
    • Rotate the dial clockwise to scroll through the diagnostic submenus.
    • Stop turning when only the Cycle Complete lamp is lit.
    • Press Start to enter error-code recall; all indicator lamps will flash once.
    • Rotate the dial clockwise to view up to four stored fault codes one at a time.
    • A lit Sensing Fill lamp signifies an F-code; if it is off, the displayed letter is E.
    • Add the numbers shown by the remaining lamps to complete the code, such as F0E5 for an unbalanced load.
    • Press and hold Start for roughly five seconds on the fifth position to erase all stored codes when needed.
    • Use the technician sheet if your model lists additional or updated codes.
    • Rotate the dial until the automatic test pattern appears then press Start.
    • The washer checks fill, drain, agitation, and spin in about three minutes.
    • The lid lock engages during the test, preventing access unless bypassed.
    • Remove the two Torx screws securing the lid striker and slide the striker off the lid.
    • Insert the striker into the lid lock to trick the control into thinking the lid is closed.
    • Keep hands and tools clear of the tub during high-speed spin to avoid injury or damage.
    • Rotate the dial to Manual Test, press Start, then turn the dial to select a specific component.
    • Choose Lid Lock first when you need to test agitation or spin functions.
    • Press Start to begin and press Start again to stop each selected action.
    • Hold the Start button for about four seconds to cancel manual testing and return the washer to standby.
    • From the diagnostic menu, rotate the dial four clicks clockwise until only the Rinse lamp is lit.
    • Press Start to begin recalibration; the washer resets sensors and runs a short verification lasting about two and a half minutes.
    • Run this routine after installing any control board, shift actuator, lid lock, or other major part.
    • Wait until all indicator lamps turn off before returning the machine to normal use.
    • Reattach the lid striker to the lid with the Torx screws.
    • Lower the top panel, slide it forward into place, and reinstall the two rear screws and harness plate screw.
    • Remove the tape and ensure the lid opens and closes smoothly.
You now have the washer’s fault codes cleared, components tested, and control system recalibrated. Use the information gathered to decide on any needed repairs and repeat diagnostics after fixes to confirm the issue is resolved.
Ben Schlichter
6,539 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 91
Past 30 Days: 321
All Time: 1,010
