Introduction
Use this guide to enter the hidden diagnostics mode on a Whirlpool-style top-load washer, run an automatic component test, and perform a recalibration cycle after replacing parts. These steps generally work on many Whirlpool-made brands, including Whirlpool, Maytag, Amana, Kenmore, Roper, and Admiral, but not GE or Hotpoint.
Step 2 Bypass the lid lock using the lid striker
Open the lid and locate the lid lock striker on the underside of the lid.
Use a Torx T15 screwdriver to remove the two screws securing the striker to the lid.
Insert the striker into the lid lock mechanism to trick the washer into thinking the lid is closed.
Step 3 Enter diagnostics mode
Rotate the cycle knob counterclockwise at least one full turn.
Rotate the knob clockwise three clicks, counterclockwise one click, and clockwise one click.
Confirm diagnostics mode by checking for five green lights flashing in parallel.
Step 4 Find the tech sheet for test descriptions and error code patterns
Look for the technical manual or tech sheet inside the washer cabinet for model-specific test descriptions.
Open the lid and look inside the washer casing to locate the tech sheet.
Tip the washer backward to create enough room to reach underneath and grab the tech sheet if needed.
Step 5 Start the automatic component test
In diagnostics mode, rotate the knob until the Spin selection light is illuminated.
Press the Start button to begin the automatic component test.
Watch for the red lid lock light to turn on and for a sequence of green lights showing test progress.
Step 6 Evaluate what the washer does during the test
Observe agitation, spinning, and any unusual noises while the automatic test runs.
Step 7 Let the automatic test complete
Wait for the spin cycle to slow down and brake until the lid lock is ready to release.
Confirm the automatic test is finished when the green Done light illuminates.
Step 8 Reset the controls for calibration
Make sure no selection lights are illuminated on the control panel.
Repeat the diagnostics entry sequence to return to diagnostics mode.
Step 9 Run the calibration cycle
Select the fourth mode labeled Spin.
Press the Start button to begin calibration.
Wait for the washer to activate the lid lock and cycle the selection lights during calibration.
Step 10 Finish calibration and restore the lid lock striker
Wait for the washer to flash all green lights and release the lid lock to indicate calibration is complete.
Remove the striker from the lid lock mechanism.
Reinstall the striker on the lid using the two Torx T15 screws.
If the automatic component test or calibration doesn’t behave as expected, use the tech sheet inside the washer to match the light patterns and test descriptions for the exact model. Reinstall the lid lock striker before returning the washer to normal use.
