How to Reupholster a Bench Cushion
    1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: step 1, image 1 of 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: step 1, image 2 of 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: step 1, image 3 of 3
      • Remove the base from the frame of the bench.
      • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
      Ask FixBot
    2. How to Reupholster a Bench Cushion: step 2, image 1 of 3 How to Reupholster a Bench Cushion: step 2, image 2 of 3 How to Reupholster a Bench Cushion: step 2, image 3 of 3
      • Lift the staples with the flathead screwdriver before going in with the pliers.
      Ask FixBot
    3. How to Reupholster a Bench Cushion: step 3, image 1 of 3 How to Reupholster a Bench Cushion: step 3, image 2 of 3 How to Reupholster a Bench Cushion: step 3, image 3 of 3
      • Use a pair of pliers to grip the staples.
      • Twist and pull the staples to remove them from the bench.
      Ask FixBot
    4. How to Reupholster a Bench Cushion: step 4, image 1 of 3 How to Reupholster a Bench Cushion: step 4, image 2 of 3 How to Reupholster a Bench Cushion: step 4, image 3 of 3
      • Place clean material down so the new fabric does not get dirty.
      • Place the fabric with the design face down on top of the clean sheet.
      • Then place the cushion, then the base face down.
      Ask FixBot
    5. How to Reupholster a Bench Cushion: step 5, image 1 of 3 How to Reupholster a Bench Cushion: step 5, image 2 of 3 How to Reupholster a Bench Cushion: step 5, image 3 of 3
      • Keep the safety lock closed when not using the staple gun.
      • When ready to use the staple gun, pull the safety lock down.
      • Insert the staples into the stapler.
      Ask FixBot
    6. How to Reupholster a Bench Cushion: step 6, image 1 of 3 How to Reupholster a Bench Cushion: step 6, image 2 of 3 How to Reupholster a Bench Cushion: step 6, image 3 of 3
      • Pull the fabric taut and staple every 4 inches.
      Ask FixBot
    7. How to Reupholster a Bench Cushion: step 7, image 1 of 3 How to Reupholster a Bench Cushion: step 7, image 2 of 3 How to Reupholster a Bench Cushion: step 7, image 3 of 3
      • Fold the corners of the fabric inward then on top.
      • Staple the fabric down twice for each corner.
      • Cut the excess fabric along the shorter sides of the base length.
      • Place the base back onto the frame.
      • If any screws were removed, screw them back on.
      Ask FixBot
Finish Line
2 other people completed this guide.
Xochitl Vara
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 45
All Time: 1,105
