Introduction
Go to step 1 ↓It is important to know how to restring cellular shades due to wear and tear from house pets, small children, and accidental damage. This guide outlines an easy repair for broken or worn strings that can be done at home instead of completely replacing the shade.
Tools
Unscrew the tassel and set aside.
Using a flathead screwdriver, open the cord stop, remove from the strings, and set aside.
Use the flathead screwdriver to take the end caps off of the top rail and set aside.
Take out the screw using the phillips screwdriver and slide the top rail off.
Using the needle nose pliers, push the cord lock clips in from the side and slide the cord lock out, removing the strings and setting the cord lock aside.
Restring the cord lock by first picking up the strings coming out of the cord lock gap. Thread them through the side opening of the cord lock and out of the back opening.
Thread them back through the back opening and out of the front opening. Make sure to pass the strings through the black rectangular piece inside the cord lock.
Pull the strings tight so that the strings are only in the front and side openings.
Once you have completed the steps for restringing your cellular shade, it is ready for use. Test it out!
4 other people completed this guide.
6 Guide Comments
Are the directions different for top down/bottom up shades?
Hi - thank you so much for this post. I followed it picture by picture and managed to restring my blind which was broken. I had been quoted NZ$150 to have it fixed so though - I may as well try to DIY and see how I went. I was nervous and had to go back and forth a few times with the steps but all in all it took me about an hour to do this job and I am so happy. String cost me NZ$12.99 and there’s plenty more to do another blind! Thank you again.
Tirzah, this is EXACTLY what I needed. My shades were slightly different (ie. the lock mechanism), but this gave me the general idea (and specifics in most areas) that helped me know how to tackle this! :) It wasn’t easy (took me 1.5 hours), but… it’s DONE! Thanks again!! :D Kurt
Where did you buy the replacement string?
