How to Restore a Dried Out Marking Pen
    1. How to Restore a Dried Out Marking Pen, Soak the tip in isopropyl alcohol: step 1, image 1 of 2 How to Restore a Dried Out Marking Pen, Soak the tip in isopropyl alcohol: step 1, image 2 of 2
      • Fill a cup with enough isopropyl alcohol for the marking pen's tip to be fully submerged.
      • Place the pen into the cup with the tip side down.
      • Keep the pen as upright as possible to prevent the alcohol from going around the side of the pen nib.
      • Wait 15 minutes for the alcohol to soak into the pen tip.
      Ask FixBot
    2. How to Restore a Dried Out Marking Pen, Remove the alcohol: step 2, image 1 of 3 How to Restore a Dried Out Marking Pen, Remove the alcohol: step 2, image 2 of 3 How to Restore a Dried Out Marking Pen, Remove the alcohol: step 2, image 3 of 3
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Remove the pen from the cup and wipe off any remaining alcohol from the pen tip.
      • On your FixMat, or another dry-erasable surface, draw the pen back and forth until you see alcohol leaving the pen nib.
      • Rotate the pen while drawing to ensure all sides of the pen nib are exercised.
      • If no alcohol is coming out of the pen nib, repeat the previous step.
      Ask FixBot
    3. How to Restore a Dried Out Marking Pen, Soak the tip in water: step 3, image 1 of 2 How to Restore a Dried Out Marking Pen, Soak the tip in water: step 3, image 2 of 2
      • Fill a cup with enough water for the marking pen's tip to be fully submerged.
      • Keep the pen as upright as possible to prevent the water from going around the side of the pen nib.
      • Wait 30 minutes for the water to soak into the pen tip.
      Ask FixBot
    4. How to Restore a Dried Out Marking Pen, Remove the water: step 4, image 1 of 3 How to Restore a Dried Out Marking Pen, Remove the water: step 4, image 2 of 3 How to Restore a Dried Out Marking Pen, Remove the water: step 4, image 3 of 3
      • Remove the pen from the cup and wipe off any remaining water from the pen tip.
      • On your FixMat, or another dry-erasable surface, draw the pen back and forth until you see ink forming in solid lines.
      • Rotate the pen while drawing to ensure all sides of the pen tip are releasing ink.
      • If no ink is coming out of the pen nib, repeat the previous step.
      Ask FixBot
    5. How to Restore a Dried Out Marking Pen: step 5, image 1 of 1
      • Congratulations! Your pen has been revived.
      Ask FixBot
For more electronics skills guides, click here.
13 other people completed this guide.
Alex Diaz-Kokaisl
250,162 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
12 Guide Comments
Unfortunately this did not help for me.
Sven Alleblas - Reply Share
This is such a great pen I wish I could find replacements.
lupinm - Reply Share
Apparently this pen that comes with the FixMat cannot be purchased, but is covered by the lifetime warranty. Send an email to support@ifixit.com to get replacement pens.
P.S. It's called the iFixit Marking Pen
Andrew Chen - Reply Share
Same for me, I repeated the guide 3 times, it didn't helped, I wish I could just open it and use a replacement, it's cheap to buy but I feel bad of throwing everything, and also the pen dries super fast I think I need to buy another one and just glue some metal plate to use with the I fix it magnetic mat
thematho - Reply Share
See my reply above
Past 24 Hours: 23
Past 7 Days: 75
Past 30 Days: 311
All Time: 12,697
