How to Restore a Bent Chopstick
  1. How to Restore a Bent Chopstick, How to Restore a Bent Chopstick: step 1, image 1 of 1
    • Using a deep pan, fill the bottom with water.
    • Set the heat to medium/low until the water begins to simmer, then bring the flame to low.
    • Do not bring the water to a boil.
    Ask FixBot
  2. How to Restore a Bent Chopstick: step 2, image 1 of 1
    • Add salt into the pan, incorporating enough salt until the water is saturated. Mix until the salt dissolves.
    • The chopstick is made of a more firm plastic, so salt is necessary because the properties interact with one another to soften the plastic.
    Ask FixBot
  3. How to Restore a Bent Chopstick: step 3, image 1 of 2 How to Restore a Bent Chopstick: step 3, image 2 of 2
    • Put on gloves to protect your hands from the heat, then gently add two dishes into the pan.
    • Ensure that the bowls will be able to tolerate the heat. The dishes are to help level the chopstick if your pan is not large enough to have the chopstick lie flat on the surface.
    Ask FixBot
  4. How to Restore a Bent Chopstick: step 4, image 1 of 1
    • Insert chopstick on top of the bowls. Make sure that the curve is facing upward.
    • When readjusting the chopstick, be sure to use tongs or other tools so you don't burn your fingers.
    Ask FixBot
  5. How to Restore a Bent Chopstick: step 5, image 1 of 1
    • Carefully take out the chopstick and gently temper by hand.
    • Be mindful of the heat when adjusting.
    • Be mindful of the strength you put into the chopstick. It may break if applying too much force.
    Ask FixBot
  6. How to Restore a Bent Chopstick: step 6, image 1 of 1
    • Repeat Step 4 and 5 until you attain the desired results.
    Ask FixBot
To reshape the chopstick, follow these instructions until it has straightened to satisfaction.
Lynne Nguyen
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 58
All Time: 3,201
