How to Restore Foggy Car Headlights
Views: 14K
View statistics:
Past 24 Hours:
18
Past 7 Days:
123
Past 30 Days:
560
All Time:
14,441
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
During normal use, headlights are exposed to UV light, dirt, chemicals, and water vapor, causing their plastic housing to oxidize and deteriorate, making the headlight foggy and potentially reducing visibility by up to 50%. While this guide demonstrates the headlight restoration on a 2003 GMC Envoy, these steps will bring any foggy headlights back to like-new conditions.
Before beginning, make sure that rain or other precipitation isn't expected in your area for the next couple days, or that you have a well-ventilated garage or covered space to work in; excessive moisture will disrupt the clear coat as it cures.
    1. How to Restore Foggy Car Headlights, How to Restore Foggy Car Headlights: step 1, image 1 of 3 How to Restore Foggy Car Headlights, How to Restore Foggy Car Headlights: step 1, image 2 of 3 How to Restore Foggy Car Headlights, How to Restore Foggy Car Headlights: step 1, image 3 of 3
      • Place masking tape around the perimeter of the headlights to protect your vehicle's paint.
      Ask FixBot
    2. How to Restore Foggy Car Headlights: step 2, image 1 of 3 How to Restore Foggy Car Headlights: step 2, image 2 of 3 How to Restore Foggy Car Headlights: step 2, image 3 of 3
      • Soak your 1000, 1500, and 2000 grit sandpaper in a bucket of clean water.
      • Once the edges begin to roll, the sandpaper is ready to use.
      Ask FixBot
    3. How to Restore Foggy Car Headlights: step 3, image 1 of 3 How to Restore Foggy Car Headlights: step 3, image 2 of 3 How to Restore Foggy Car Headlights: step 3, image 3 of 3
      • Use wet 1000 grit sandpaper and light pressure to sand the plastic in circular patterns. When you notice that the small scratches look identical across the entire headlight, sand horizontally until all the small scratches appear horizontal.
      • Use a spray-bottle filled with water to keep the sandpaper and the headlight wet throughout the entire sanding process. Dry sanding can damage plastic.
      • Repeat the process with 1500, then 2000 grit sandpaper.
      Ask FixBot
    4. How to Restore Foggy Car Headlights: step 4, image 1 of 3 How to Restore Foggy Car Headlights: step 4, image 2 of 3 How to Restore Foggy Car Headlights: step 4, image 3 of 3
      • Thoroughly dry the headlights.
      • Use a microfiber cloth and moderate pressure to apply a thin layer of carnauba wax to the entire surface of the headlights.
      • Work the wax into the plastic using small circular motions.
      • Wait until the wax dries to a haze, then buff it off with a clean microfiber towel.
      Ask FixBot
    5. How to Restore Foggy Car Headlights: step 5, image 1 of 3 How to Restore Foggy Car Headlights: step 5, image 2 of 3 How to Restore Foggy Car Headlights: step 5, image 3 of 3
      • Use 70% isopropyl alcohol and paper towels to remove any residue on the headlights.
      • It is very important remove any wax residue, as it will prevent the clear coat from properly binding.
      Ask FixBot
    6. How to Restore Foggy Car Headlights: step 6, image 1 of 3 How to Restore Foggy Car Headlights: step 6, image 2 of 3 How to Restore Foggy Car Headlights: step 6, image 3 of 3
      • Tape down newspaper or plastic bags at least a foot in radius surrounding the headlights, to avoid damaging your vehicle's paint during the clear coat application.
      • Make sure there are no uncovered gaps.
      Ask FixBot
    7. How to Restore Foggy Car Headlights: step 7, image 1 of 3 How to Restore Foggy Car Headlights: step 7, image 2 of 3 How to Restore Foggy Car Headlights: step 7, image 3 of 3
      • Make sure the headlights are completely dry and that it isn't going to rain/snow in the near future, or that you have a well-ventilated, covered space to work in.
      • Shake the clear coat well and apply a thin coat evenly across the entire headlight, using long, quick strokes to avoid pooling.
      • Wait for the clear coat to fully dry before applying the next coat. Apply at least two coats for better results.
      • Read the product label and follow the manufacturer's application directions
      • Do not apply clear coat in poorly ventilated conditions.
      Ask FixBot
    8. How to Restore Foggy Car Headlights: step 8, image 1 of 1
      • Repeat Steps 3 and 4 to achieve the best result, using only 2,000 grit sandpaper and very light pressure to smooth the clear coat.
      Ask FixBot
Enjoy your crystal-clear headlights!
18 other people completed this guide.
2 Guide Comments
Thank you it is very much clear to understand.
muthukumarage chandrakumara - Reply Share
Excelente, muy sencillo y practico, ademas funciona!
Juan Jose Arellano - Reply Share
Past 24 Hours: 18
Past 7 Days: 123
Past 30 Days: 560
All Time: 14,441
