Up to 20% off select tools
How to Restain Wood
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
94
All Time:
1,138
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
How to Restain Wood
Introduction
Go to step 1 ↓
Before starting this project, you should wear gloves and a mask if possible for the sanding. Also this process is useful so you can make sure you can keep your wood looking good and protected so it doesn’t rot and the wood can last longer.
    1. How to Restain Wood, How to Restain Wood: step 1, image 1 of 1
      • Wipe down the wood with a rag or a towel to take clean the wood.
      Ask FixBot
    2. How to Restain Wood: step 2, image 1 of 1
      • Sand down the wood until you get a soft surface.
      • If your wood is already stained, then sand the wood until it is clear of the old stain.
      Ask FixBot
    3. How to Restain Wood: step 3, image 1 of 1
      • Wipe down the sanded part with the rag so when you paint on the wood you don't get the brush dirty with dust from the wood.
      Ask FixBot
    4. How to Restain Wood: step 4, image 1 of 1
      • Paint the wood and make sure to cover all surfaces of the wood.
      • Let it dry and repaint the wood a couple more times to ensure all of the surfaces have been properly coated.
      Ask FixBot
To do this process again just follow these steps again and this process should be done again in 6-7 months
Author
with
Brian Morales
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 94
All Time: 1,138
