How to Replace the Trigger Spring of a Spray Bottle
    1. How to Replace the Trigger Spring of a Spray Bottle, Trigger Spring: step 1, image 1 of 3 How to Replace the Trigger Spring of a Spray Bottle, Trigger Spring: step 1, image 2 of 3 How to Replace the Trigger Spring of a Spray Bottle, Trigger Spring: step 1, image 3 of 3
      • Slightly and gently spread the plastic head so you can easily slide out the trigger lever to access the remaining parts.
      • Be careful not to push too hard when holding the plastic open to avoid finger injury or product breakage.
      Ask FixBot
    2. How to Replace the Trigger Spring of a Spray Bottle: step 2, image 1 of 3 How to Replace the Trigger Spring of a Spray Bottle: step 2, image 2 of 3 How to Replace the Trigger Spring of a Spray Bottle: step 2, image 3 of 3
      • After separating the trigger lever from the rest of the bottle, place the spring into the opening slot.
      • You can alternatively start by connecting the larger opening of the smaller plastic part with the spring.
      Ask FixBot
    3. How to Replace the Trigger Spring of a Spray Bottle: step 3, image 1 of 2 How to Replace the Trigger Spring of a Spray Bottle: step 3, image 2 of 2
      • Gently but firmly push in the smaller plastic slot.
      Ask FixBot
    4. How to Replace the Trigger Spring of a Spray Bottle: step 4, image 1 of 2 How to Replace the Trigger Spring of a Spray Bottle: step 4, image 2 of 2
      • Connect the longer plastic piece, ensuring that the small gap splitting one end of the piece is horizontally facing out.
      Ask FixBot
    5. How to Replace the Trigger Spring of a Spray Bottle: step 5, image 1 of 2 How to Replace the Trigger Spring of a Spray Bottle: step 5, image 2 of 2
      • Slide the outlined plastic part into the bottle head, ensuring that all sides are inside the head and parallel to the bottom plastic part.
      • Confirm that the line in the middle of the trigger lever aligns with the gap in the previously attached plastic part.
      Ask FixBot
    6. How to Replace the Trigger Spring of a Spray Bottle: step 6, image 1 of 2 How to Replace the Trigger Spring of a Spray Bottle: step 6, image 2 of 2
      • Insert the first protruding piece into its respective opening, then carefully pop the other side in.
      • Maintain the center pieces' alignment when reconnecting to ensure functionality.
      Ask FixBot
    7. How to Replace the Trigger Spring of a Spray Bottle: step 7, image 1 of 1
      • Test your final assembled product.
      Ask FixBot
Finish Line
Chanelle Abi Najem
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 36
Past 7 Days: 167
Past 30 Days: 669
All Time: 3,998
