How to Replace a Watch Strap
    1. How to Replace a Watch Strap, Watch Strap: step 1, image 1 of 1
      • Begin by laying a soft towel or fabric on a table.
      • This will prevent accidental scratches during the repair.
      • We will be performing all repairs from the back of the watch, to avoid scratching the visible watch face.
      Ask FixBot
    2. How to Replace a Watch Strap: step 2, image 1 of 2 How to Replace a Watch Strap: step 2, image 2 of 2
      • Before you begin, consider practicing with your tool to compress the bar.
      • Hold the watch with the face in your palm, with one end of the strap free to move.
      Ask FixBot
    3. How to Replace a Watch Strap: step 3, image 1 of 2 How to Replace a Watch Strap: step 3, image 2 of 2
      • Insert your Spring Bar tool into the gap between the end of the watch strap and the watch body.
      • Press down and compress the spring. By pushing the bar away from the body, one end of the spring bar should come loose.
      Ask FixBot
    4. How to Replace a Watch Strap: step 4, image 1 of 2 How to Replace a Watch Strap: step 4, image 2 of 2
      • Being cautious as to not damage the body or spring bar, slide the bar out from its hole and remove the strap.
      • Set this half of the strap with the spring bar aside until we remove the other strap.
      Ask FixBot
    5. How to Replace a Watch Strap: step 5, image 1 of 3 How to Replace a Watch Strap: step 5, image 2 of 3 How to Replace a Watch Strap: step 5, image 3 of 3
      • Repeat steps 2-4 to remove the other end of the watch strap.
      Ask FixBot
    6. How to Replace a Watch Strap: step 6, image 1 of 3 How to Replace a Watch Strap: step 6, image 2 of 3 How to Replace a Watch Strap: step 6, image 3 of 3
      • Replace the old or damaged watch straps by simply sliding the spring bars out and into the new straps
      • Be careful not to put the new straps on the wrong side of the body.
      Ask FixBot
    7. How to Replace a Watch Strap: step 7, image 1 of 3 How to Replace a Watch Strap: step 7, image 2 of 3 How to Replace a Watch Strap: step 7, image 3 of 3
      • Begin the reassembly by sliding the bottom of the spring bar into its hole on the watch body.
      • Remember, always work from the back of the watch to prevent visible scratches.
      • Using your spring bar tool, compress the bar and slide back into place.
      • The spring bar should click when installed correctly.
      Ask FixBot
    8. How to Replace a Watch Strap: step 8, image 1 of 3 How to Replace a Watch Strap: step 8, image 2 of 3 How to Replace a Watch Strap: step 8, image 3 of 3
      • Repeat step 7 on the other side of the watch.
      • Give the watch a tug to make sure all parts are installed correctly.
      Ask FixBot
You have completed the fix! We hope this guide has helped.
6 other people completed this guide.
domenicruffino
308 Reputation
1 Guide authored
Cal Poly, Team 14-2, Green Fall 2015 Member of Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 33
Past 30 Days: 161
All Time: 12,796
