How to Replace a Skateboard Deck
  1. How to Replace a Skateboard Deck, Deck: step 1, image 1 of 1
    • Use the 3/8" socket to take off the nut
    • Use the phillips side to hold the screw in place.
    • Remove the nut
    • Repeat for all four nuts on the truck
    • Repeat for the second truck
    Ask FixBot
  2. How to Replace a Skateboard Deck: step 2, image 1 of 2 How to Replace a Skateboard Deck: step 2, image 2 of 2
    • Remove both trucks from the board
    • Remove all 8 screws
    Ask FixBot
  3. How to Replace a Skateboard Deck: step 3, image 1 of 3 How to Replace a Skateboard Deck: step 3, image 2 of 3 How to Replace a Skateboard Deck: step 3, image 3 of 3
    • Line up the grip with the board
    • Ensure it covers the entirety of the board and hangs over the edge
    • Peel the back off at one end enough to reveal the sticky side.
    • Expose about four inches
    • Attach the peeled side to one end of the board
    • Press the grip onto the board slowly and work your way across the board
    • Ensure that there is no air bubbles forming when applying the grip
    Ask FixBot
  4. How to Replace a Skateboard Deck: step 4, image 1 of 2 How to Replace a Skateboard Deck: step 4, image 2 of 2
    • Use the phillips head screwdriver to trace the edge of the board
    • Ensure it can be seen all the way around the board
    Ask FixBot
  5. How to Replace a Skateboard Deck: step 5, image 1 of 1
    • Trim the grip along the trace you made with the box cutter
    • Use long and smooth motions for straight trims
    • Trim up the jagged edges left on the grip on the edge of the board
    Ask FixBot
  6. How to Replace a Skateboard Deck: step 6, image 1 of 1
    • Sand the edges with the left over grip
    • This is to ensure the grip fully applies to the board
    Ask FixBot
  7. How to Replace a Skateboard Deck: step 7, image 1 of 2 How to Replace a Skateboard Deck: step 7, image 2 of 2
    • Poke a hole with the screw from the bottom of the deck
    • Remove the screw
    • Insert it through the top on the deck
    • Repeat for all 4 holes
    • Repeat on the opposite side with the other truck
    Ask FixBot
  8. How to Replace a Skateboard Deck: step 8, image 1 of 3 How to Replace a Skateboard Deck: step 8, image 2 of 3 How to Replace a Skateboard Deck: step 8, image 3 of 3
    • Use the 3/8" socket to screw on the nut
    • The hangar should face outwards
    • Tighten them until they're snug
    • Overtightening can damage the deck
    Ask FixBot
Finish Line
Dylan Norris
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 78
All Time: 1,174
