How to Replace a Fan Duct Motor
    1. How to Replace a Fan Duct Motor, Fan Duct Motor: step 1, image 1 of 3 How to Replace a Fan Duct Motor, Fan Duct Motor: step 1, image 2 of 3 How to Replace a Fan Duct Motor, Fan Duct Motor: step 1, image 3 of 3
      • Unplug the fan duct motor from its power source.
      Ask FixBot
    2. How to Replace a Fan Duct Motor: step 2, image 1 of 2 How to Replace a Fan Duct Motor: step 2, image 2 of 2
      • To remove the cord secure nut from the housing, twist the nut counterclockwise until the screw slides down easily.
      Ask FixBot
    3. How to Replace a Fan Duct Motor: step 3, image 1 of 2 How to Replace a Fan Duct Motor: step 3, image 2 of 2
      • Using a Phillips head screwdriver, undue the screw attached to the green ground wiring. It will now stay disconnected.
      Ask FixBot
    4. How to Replace a Fan Duct Motor: step 4, image 1 of 1
      • Using a pair of scissors, carefully clip the zip ties and disconnect the motor from the power cord. You will no longer need a motor or wires attached. Assure a safe place for your power cord is set to the side continued onward.
      Ask FixBot
    5. How to Replace a Fan Duct Motor: step 5, image 1 of 3 How to Replace a Fan Duct Motor: step 5, image 2 of 3 How to Replace a Fan Duct Motor: step 5, image 3 of 3
      • Undue first two screws on the side of the ductal housing. Remove and set the screw and two locking washers to the side.
      • You will need the screws and locking washers to attach new fan duct motor unless new motor comes with set up.
      Ask FixBot
    6. How to Replace a Fan Duct Motor: step 6, image 1 of 1
      • Remove bracket and fan blade from motor. Lift the blade from the duct and set aside.
      Ask FixBot
A.C Kauffman
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 33
All Time: 129
