How to Replace a Damaged Gutter Segment
    1. How to Replace a Damaged Gutter Segment, Eavestrough Gutter Segment: step 1, image 1 of 1
      • Identify the section of the gutter system that needs to be replaced, specifically the middle gutter.
      Ask FixBot
    2. How to Replace a Damaged Gutter Segment: step 2, image 1 of 2 How to Replace a Damaged Gutter Segment: step 2, image 2 of 2
      • Using a screwdriver, remove the screws from the strip that holds the gutter to the wall.
      • Repeat this process for each strip along the length of the gutter.
      • Spread apart the strips to release the gutter.
      • When spreading apart the strips, they may have sharp edges. To ensure your safety, please use caution and wear protective gloves.
      Ask FixBot
    3. How to Replace a Damaged Gutter Segment: step 3, image 1 of 3 How to Replace a Damaged Gutter Segment: step 3, image 2 of 3 How to Replace a Damaged Gutter Segment: step 3, image 3 of 3
      • Locate the connecting points between the bottom gutter and the middle gutter.
      • Using a screwdriver, remove the screws.
      • Separate the bottom gutter from the middle gutter by sliding them apart.
      Ask FixBot
    4. How to Replace a Damaged Gutter Segment: step 4, image 1 of 3 How to Replace a Damaged Gutter Segment: step 4, image 2 of 3 How to Replace a Damaged Gutter Segment: step 4, image 3 of 3
      • Detach the top gutter from the connected fittings.
      • Position yourself securely on a ladder or elevated platform at the appropriate height to access the top gutter.
      • Place the removed top gutter and the middle gutter on the ground.
      • Inspect both the top gutter and the middle gutter for any damage. Assess whether they need to be entirely replaced or if repairs can be made.
      • If the damaged area is serious, you can only replace with a new segment (looking for environmentally friendly materials to protect the earth).
      Ask FixBot
    5. How to Replace a Damaged Gutter Segment: step 5, image 1 of 3 How to Replace a Damaged Gutter Segment: step 5, image 2 of 3 How to Replace a Damaged Gutter Segment: step 5, image 3 of 3
      • Slide the new middle gutter into the top gutter, inserting it gently until they are firmly connected.
      • Double-check that the alignment is correct and there are no gaps between the sections to avoid any drainage.
      • With the middle and top gutters connected, reattach the assembled gutters to the connected fittings.
      Ask FixBot
    6. How to Replace a Damaged Gutter Segment: step 6, image 1 of 3 How to Replace a Damaged Gutter Segment: step 6, image 2 of 3 How to Replace a Damaged Gutter Segment: step 6, image 3 of 3
      • Load a screw into the strip, positioning it so that it can be screwed into the holes of both the strip and the gutter.
      • Fold the strip around the gutter, aligning the holes of the strip with the corresponding holes on the gutter.
      • Screw the screws into the holes of the strip and the gutter, using a screwdriver.
      • Repeat this process for each strip along the length of the new middle gutter.
      • Take care not to overtighten the screw, as it may damage the gutter or strip the threads.
      Ask FixBot
    7. How to Replace a Damaged Gutter Segment: step 7, image 1 of 3 How to Replace a Damaged Gutter Segment: step 7, image 2 of 3 How to Replace a Damaged Gutter Segment: step 7, image 3 of 3
      • Position the bottom gutter in its intended location, ensuring that the holes on both pieces line up properly.
      • Using a screwdriver, tighten the screws to fasten the middle and bottom gutters together.
      • Replacement Complete!
      Ask FixBot
Finish Line
2 other people completed this guide.
Gavin Luc
163 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 176
All Time: 3,423
