How to Replace a Curtain Rod
    1. How to Replace a Curtain Rod, Curtain Rod: step 1, image 1 of 2 How to Replace a Curtain Rod, Curtain Rod: step 1, image 2 of 2
      • Remove the rod off the hook from the wall carefully with your hands.
      Ask FixBot
    2. How to Replace a Curtain Rod: step 2, image 1 of 3 How to Replace a Curtain Rod: step 2, image 2 of 3 How to Replace a Curtain Rod: step 2, image 3 of 3
      • Remove the screws from the hooks using a Phillips screwdriver or power drill with a Phillips head.
      Ask FixBot
    3. How to Replace a Curtain Rod: step 3, image 1 of 2 How to Replace a Curtain Rod: step 3, image 2 of 2
      • Use the tape measure to determine screw placement on the wall for the new curtain rod.
      Ask FixBot
    4. How to Replace a Curtain Rod: step 4, image 1 of 2 How to Replace a Curtain Rod: step 4, image 2 of 2
      • Replace the Phillips head in the power drill with a drill bit.
      • Drill the holes into the wall for the screws to secure firmly.
      Ask FixBot
    5. How to Replace a Curtain Rod: step 5, image 1 of 1
      • Place the screw into the hole on the hook and drill it into the holes on the wall.
      Ask FixBot
    6. How to Replace a Curtain Rod: step 6, image 1 of 2 How to Replace a Curtain Rod: step 6, image 2 of 2
      • Measure an equal distance between each hook. Repeat Step 5 for drilling in each hook on the wall.
      Ask FixBot
    7. How to Replace a Curtain Rod: step 7, image 1 of 2 How to Replace a Curtain Rod: step 7, image 2 of 2
      • Insert the rod into the curtain hole, leaving at least two inches of the rod on each side uncovered for hook placement.
      Ask FixBot
    8. How to Replace a Curtain Rod: step 8, image 1 of 2 How to Replace a Curtain Rod: step 8, image 2 of 2
      • Place the rod onto the curve of the hook for attachment. Then straighten out the curtain across the window.
      Ask FixBot
Finish Line
Andrew Pfeiffer
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 104
All Time: 2,319
