How to Replace a Coffee Tabletop Glass
    1. How to Replace a Coffee Tabletop Glass, Coffee Table Glass: step 1, image 1 of 2 How to Replace a Coffee Tabletop Glass, Coffee Table Glass: step 1, image 2 of 2
      • Flip the coffee table base upside down on an empty area.
      Ask FixBot
    2. How to Replace a Coffee Tabletop Glass: step 2, image 1 of 1
      • Use a cleaning spray to clean the surface of the glass table.
      • Use gloves while cleaning the table. The glass cleaner spray may contain toxic chemicals.
      Ask FixBot
    3. How to Replace a Coffee Tabletop Glass: step 3, image 1 of 2 How to Replace a Coffee Tabletop Glass: step 3, image 2 of 2
      • Use a Phillips #2 screwdriver to remove one 1/4 in.-20 x 1-1/2 in. socket cap screw from the side of the glass.
      • Repeat the process for the other 1/4 in.-20 x 1-1/2 in. socket cap screw.
      • The appearance of this screw may differ from table to table, but the procedure remains the same. Use the appropriate screwdriver to open the screws.
      Ask FixBot
    4. How to Replace a Coffee Tabletop Glass: step 4, image 1 of 2 How to Replace a Coffee Tabletop Glass: step 4, image 2 of 2
      • Remove the coffee table legs piece by piece.
      Ask FixBot
    5. How to Replace a Coffee Tabletop Glass: step 5, image 1 of 1
      • Remove the glass.
      • Remember that glass can be shattered or partially damaged. Use gloves to avoid possible cuts.
      Ask FixBot
    6. How to Replace a Coffee Tabletop Glass: step 6, image 1 of 1
      • Replace the broken/ damaged glass with the new one.
      Ask FixBot
Jasrin Kaur
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 73
All Time: 4,064
