How to Replace a Cabinet Door
  1. How to Replace a Cabinet Door, Cabinet Door: step 1, image 1 of 1
    • Using a screwdriver, either a Flathead or a Phillips, remove the screws starting from the bottom of the door all the way to the top of the door to prevent the door from swinging.
  2. How to Replace a Cabinet Door: step 2, image 1 of 1
    • Next using a screwdriver, remove the screws attaching the hinge to the door.
  3. How to Replace a Cabinet Door: step 3, image 1 of 3 How to Replace a Cabinet Door: step 3, image 2 of 3 How to Replace a Cabinet Door: step 3, image 3 of 3
    • Place the new cabinet on a flat surface. Then line up the old (or new) hinge's to holes on the door.
  4. How to Replace a Cabinet Door: step 4, image 1 of 3 How to Replace a Cabinet Door: step 4, image 2 of 3 How to Replace a Cabinet Door: step 4, image 3 of 3
    • Finally, line up the hinge’s holes with the holes from the previous cabinet door. Then screw the new door on.
To reassemble your cabinet, follow these instructions in reverse order.
Kayleah Cumpian
151 Reputation
1 Guide authored
Texas Tech, Team 22-7, Rauch Spring 2016 Member of Texas Tech, Team 22-7, Rauch Spring 2016
TTU-RAUCH-S16S22G7
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 136
All Time: 2,553
