How to Replace a Broken Toilet Flapper Chain
    1. How to Replace a Broken Toilet Flapper Chain, Toilet Flapper Chain: step 1, image 1 of 3 How to Replace a Broken Toilet Flapper Chain, Toilet Flapper Chain: step 1, image 2 of 3 How to Replace a Broken Toilet Flapper Chain, Toilet Flapper Chain: step 1, image 3 of 3
      • Lift the toilet lid off the toilet and set it aside.
      Ask FixBot
    2. How to Replace a Broken Toilet Flapper Chain: step 2, image 1 of 2 How to Replace a Broken Toilet Flapper Chain: step 2, image 2 of 2
      • Turn the water supply valve to your toilet clockwise until it's fully closed.
      Ask FixBot
    3. How to Replace a Broken Toilet Flapper Chain: step 3, image 1 of 2 How to Replace a Broken Toilet Flapper Chain: step 3, image 2 of 2
      • Push the flush handle down (or up, depending on the toilet) to flush the water out.
      • Keep holding the handle until the flush is complete and the tank is empty.
      • You may need to directly lift the flapper if pushing the handle down does not work.
      Ask FixBot
    4. How to Replace a Broken Toilet Flapper Chain: step 4, image 1 of 2 How to Replace a Broken Toilet Flapper Chain: step 4, image 2 of 2
      • Unhook the chain from the trip lever arm.
      Ask FixBot
    5. How to Replace a Broken Toilet Flapper Chain: step 5, image 1 of 3 How to Replace a Broken Toilet Flapper Chain: step 5, image 2 of 3 How to Replace a Broken Toilet Flapper Chain: step 5, image 3 of 3
      • Unclip each side from the mounting post on the flush valve to remove the flapper.
      Ask FixBot
    6. How to Replace a Broken Toilet Flapper Chain: step 6, image 1 of 1
      • Pull on the hooks securing the chain and slide the old, broken chain off.
      Ask FixBot
    7. How to Replace a Broken Toilet Flapper Chain: step 7, image 1 of 1
      • Slide one end of the new chain onto one of the flapper's hooks, and close the hooks up by pushing them in.
      • If your new chain is too long, you may need to use some pliers to cut the chain to a length similar to the old chain to prevent slack (and a bad flush!).
      Ask FixBot
Alston T.
145 Reputation
1 Guide authored
CSU Los Angeles, Team 6-67, Harris Fall 2025 Member of CSU Los Angeles, Team 6-67, Harris Fall 2025
CSULA-HARRIS-F25S6G67
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 83
Past 30 Days: 364
All Time: 1,461
