How to Replace Keys on a Keyboard
    1. How to Replace Keys on a Keyboard, Individual Keys: step 1, image 1 of 2 How to Replace Keys on a Keyboard, Individual Keys: step 1, image 2 of 2
      • Loosen the key by prying all four corners gently with your spudger.
      • Make sure your keyboard is unplugged before performing any of these steps.
      Ask FixBot
    2. How to Replace Keys on a Keyboard: step 2, image 1 of 2 How to Replace Keys on a Keyboard: step 2, image 2 of 2
      • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
      • If the key will not come out, or seems like too much force is needed, try step one again.
      Ask FixBot
    3. How to Replace Keys on a Keyboard: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
      • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
      Ask FixBot
    4. How to Replace Keys on a Keyboard: step 4, image 1 of 1
      • Clean your keys with compressed air by blowing around the removed key.
      Ask FixBot
    5. How to Replace Keys on a Keyboard: step 5, image 1 of 2 How to Replace Keys on a Keyboard: step 5, image 2 of 2
      • Push in the clean keys until you hear a popping sound.
      • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
      • If you removed multiple keys, make sure they are in their proper spot and orientation.
      Ask FixBot
Congratulations! You now have a keyboard with fully functional keys!
7 other people completed this guide.
Cooper
502 Reputation
2 Guides authored
Cal Poly, Team 24-6, Green Winter 2015 Member of Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Members
60 Guides authored
2 Guide Comments
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Reply Share
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Reply Share
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 189
All Time: 21,798
