How to Replace Concealed Cabinet Hinges
    1. How to Replace Concealed Cabinet Hinges, Hinge: step 1, image 1 of 3 How to Replace Concealed Cabinet Hinges, Hinge: step 1, image 2 of 3 How to Replace Concealed Cabinet Hinges, Hinge: step 1, image 3 of 3
      • Remove the screws that are attached to the cabinet door.
      • Unscrew the top and bottom hinges even if you are only replacing one hinge.
      • Remove the cabinet door from the hinge.
      • You may need to wiggle or pry the door off.
      Ask FixBot
    2. How to Replace Concealed Cabinet Hinges: step 2, image 1 of 2 How to Replace Concealed Cabinet Hinges: step 2, image 2 of 2
      • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
      • Only the hinge being replaced needs to be removed.
      Ask FixBot
    3. How to Replace Concealed Cabinet Hinges: step 3, image 1 of 3 How to Replace Concealed Cabinet Hinges: step 3, image 2 of 3 How to Replace Concealed Cabinet Hinges: step 3, image 3 of 3
      • Insert the new hinge into the cabinet door's pre-cut hole.
      • Attach the hinge with the provided screws.
      • To avoid striping the screws, do not over tighten.
      Ask FixBot
    4. How to Replace Concealed Cabinet Hinges: step 4, image 1 of 1
      • Reattach the cabinet door to the cabinet frame.
      • Do not tighten the screws all the way. You will need to align the door later.
      • You may need a friend to hold the door while you screw it back into place.
      Ask FixBot
    5. How to Replace Concealed Cabinet Hinges: step 5, image 1 of 2 How to Replace Concealed Cabinet Hinges: step 5, image 2 of 2
      • Lift or lower the cabinet door to align the hinges with its original location.
      • Changes in wood stain can serve as a useful alignment guide.
      • Tighten all the screws.
      Ask FixBot
    6. How to Replace Concealed Cabinet Hinges: step 6, image 1 of 3 How to Replace Concealed Cabinet Hinges: step 6, image 2 of 3 How to Replace Concealed Cabinet Hinges: step 6, image 3 of 3
      • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
      • Loosen the adjustment screws, but do not remove them.
      • Slide the cabinet door to your desired position.
      • Tighten the screws.
      Ask FixBot
    7. How to Replace Concealed Cabinet Hinges: step 7, image 1 of 1
      • Use this step if your cabinet door closes too hard or does not completely close.
      • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
      • Do not completely remove this screw.
      Ask FixBot
Finish Line
4 other people completed this guide.
Naomi Frazier
171 Reputation
1 Guide authored
UC Davis, Team S4-G4, Cole Spring 2017 Member of UC Davis, Team S4-G4, Cole Spring 2017
UCD-COLE-S17S4G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 65
Past 30 Days: 294
All Time: 31,839
