How to Repair the Creality3D Ender 7 Z-axis Control
  1. How to Repair the Creality3D  Ender 7 Z-axis Control, diagnostic: step 1, image 1 of 2 How to Repair the Creality3D  Ender 7 Z-axis Control, diagnostic: step 1, image 2 of 2
    • If the Z-axis is no longer working.
    • disconnect the power cable to the printer and open the bottom and on the mother board switch the cable to Z-step motor with the one to the extruder step-motor.
    • close the bottom and start the printer in setting mode.
    • request the extruder to move forward a little, and if the Z-motor move, you can confirm the Z-motor is working as expected.
    • You can order a new driver online.
    • I choose a DM556, because it is cheaper than the DM542.
    Ask FixBot
  2. How to Repair the Creality3D  Ender 7 Z-axis Control, Mechanical mounting of the driver: step 2, image 1 of 1
    • Disconnect the power cable again and open the bottom of the printer
    • There is enough space to place the driver as on the picture.
    • You need to drill two hole in the frame on the back for the two screws to hold the driver.
    • Take you time to mark where you need to drill as it will be visible from the outside later.
    Ask FixBot
  3. How to Repair the Creality3D  Ender 7 Z-axis Control, Connect the power: step 3, image 1 of 1
    • Connect the power directly to the 12V power supply.
    • Cut the cable to the Z-axis at approx 15cm from the plug of the motherboard.
    • Save the 15cm left!
    • Connect the A-, A+, B- and B+ to the right place.
    • Use as much as possible the X and Y connection as a reference to connect the Z!
    Ask FixBot
  4. How to Repair the Creality3D  Ender 7 Z-axis Control, reconnect the control signals: step 4, image 1 of 1
    • Use new wires to connect the control signals from the mother board to the external driver.
    • Carry over the way is is connected on X and Y.
    • use later zip-tie to prevent all the cable you add to move and vibrate when the printer will be running.
    Ask FixBot
  5. How to Repair the Creality3D  Ender 7 Z-axis Control, Move the control plug: step 5, image 1 of 1
    • The whole idea is to bypass the original onboard driver (which is under dimension, I think).
    • You can remove the mounting screws of the motherboard to remove the connector and reuse it on the similar position as X and Y.
    • OR you can simply solder the each wire, one by one.
    Ask FixBot
  6. How to Repair the Creality3D  Ender 7 Z-axis Control, adjusting settings: step 6, image 1 of 1
    • I selected 2,1A: SW1=off SW2=on SW3=on.
    • I selected 3200pulses/rotation: SW5=on SW6=on SW7=off SW8=on to match the the movement of the printing surface.
    • You can close the bottom of the frame and connect back the power cable to give a try!
    Ask FixBot
Finish Line
Flavien Driard
421 Reputation
3 Guides authored
1 Guide Comment
I’m having an issue with my X-Y motors one of the stepper boards gave out and I bought two of these as a replacement where would I start
Corey Stanley - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 38
All Time: 1,886
