How to Repair a Warped Cooking Pan
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
61
Past 30 Days:
278
All Time:
2,422
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Frequent use and storage of cooking pans can cause them to warp and deteriorate over time. Cooking pans can last for years when they’re given proper care. If you happen to accidentally damage your cooking pan, the tools and steps included in this repair will help salvage your pan. Once you have finished your repair, please store it in a safe location to prevent future damage.
    1. How to Repair a Warped Cooking Pan, How to Repair a Warped Cooking Pan: step 1, image 1 of 1
      • Locate the hard surface you will use for the repair.
      Ask FixBot
    2. How to Repair a Warped Cooking Pan: step 2, image 1 of 1
      • Place one of the two towels on top of the hard surface.
      Ask FixBot
    3. How to Repair a Warped Cooking Pan: step 3, image 1 of 1
      • Turn on the stove to medium heat to warm up the bottom of the cooking pan that is warped.
      Ask FixBot
    4. How to Repair a Warped Cooking Pan: step 4, image 1 of 1
      • As soon as the pan is warm or hot to the touch, quickly remove it from the stove.
      • Turn off the stove and place the pan, bottom up, on top of the towel that is placed on the hard surface.
      Ask FixBot
    5. How to Repair a Warped Cooking Pan: step 5, image 1 of 2 How to Repair a Warped Cooking Pan: step 5, image 2 of 2
      • Place the second towel on top of the bottom of the pan that is facing upward.
      Ask FixBot
    6. How to Repair a Warped Cooking Pan: step 6, image 1 of 1
      • Place the block of wood on top of the second towel that is placed on the pan.
      Ask FixBot
    7. How to Repair a Warped Cooking Pan: step 7, image 1 of 2 How to Repair a Warped Cooking Pan: step 7, image 2 of 2
      • Carefully hammer directly onto the block of wood.
      • Make sure that the block of wood is still firmly on top of the bottom of the pan. This will help ensure that the pan is repaired properly.
      Ask FixBot
    8. How to Repair a Warped Cooking Pan: step 8, image 1 of 1
      • Your cooking pan should no longer be warped. You are finished!
      Ask FixBot
Finish Line
angieaguirre
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 61
Past 30 Days: 278
All Time: 2,422
