How to Repair a Vileda Turbo Mop Bucket Set
  1. How to Repair a Vileda Turbo Mop Bucket Set, How to Repair a Vileda Turbo Mop Bucket Set: step 1, image 1 of 2 How to Repair a Vileda Turbo Mop Bucket Set, How to Repair a Vileda Turbo Mop Bucket Set: step 1, image 2 of 2
    • No Parts Required
    Ask FixBot
  2. How to Repair a Vileda Turbo Mop Bucket Set: step 2, image 1 of 1
    • Run the few drops of oil down the chrome shaft
    Ask FixBot
Get back to work !
5 other people completed this guide.
Paul
933 Reputation
4 Guides authored
12 Guide Comments
I had the same problem but fixed it slightly different. I turned the empty bucket upside down, removed the four pz2 screws. Lifted out gearing in one piece. Removed rust/debris from two month old bucket stainless steel shaft and sprayed with water dispersant liquid. Reassembled. May sound complicated but very easy and thorough job. Only about 10 minutes, screwdriver and lubricant spray.
jimdeane77 - Reply Share
Hi Jim Thanks for your idea. Next time I will go a bit deeper into it. My bucket was already full and ready to go. The few drops of oil got it going straight away.
Paul - Reply Share
Sometimes there is too much rust into the gearing.
I replace it with “Octagonal One Way Needle Roller Bearing HF081412 8*14*12mm Fit for EasyMop” found on EBAY (10=$8.90 !)
Like a new ! I takes 10’ !
geek5537 - Reply Share
Thanks for the heads up , geek5537. Will take note of the part number. Stay safe.
Paul - Reply Share
Where I can buy new pedal? Mine is broken.
Emil Hakobian - Reply Share
Past 24 Hours: 19
Past 7 Days: 150
Past 30 Days: 692
All Time: 36,344
