How to Repair a Stuck Trailer Jack
  1. How to Repair a Stuck Trailer Jack, How to Repair a Stuck Trailer Jack: step 1, image 1 of 1
    • Remove the trailer jack from trailer.
    • Use a 19mm box end wrench to remove the 19mm hex head bolt that secures the jack to the trailer.
    • Slide the jack off the trailer to remove.
    • Be sure to safely support the trailer before removing (With a vehicle or jack stands).
    Ask FixBot
  2. How to Repair a Stuck Trailer Jack: step 2, image 1 of 1
    • Remove the nut and bolt that secures the handle to the jack.
    • Use two half-inch box end wrenches to remove the half-inch bolt and nut.
    • Slide the handle upward after removing the nut and bolt to remove the handle.
    • Set the handle aside.
    • Screw the jack to the most extended spot the jack will go.
    Ask FixBot
  3. How to Repair a Stuck Trailer Jack: step 3, image 1 of 1
    • Lift the spacer or washer upward.
    • Set the washer aside.
    Ask FixBot
  4. How to Repair a Stuck Trailer Jack: step 4, image 1 of 1
    • Turn the jack upside down and use a hammer to gently slide the upper assembly off the lower assembly.
    • Set the upper assembly aside.
    Ask FixBot
  5. How to Repair a Stuck Trailer Jack: step 5, image 1 of 1
    • Begin to remove the rust and corrosion using a die-grinder and steel wire wheel.
    Ask FixBot
  6. How to Repair a Stuck Trailer Jack: step 6, image 1 of 1
    • Apply grease or anti-seize lubricant to the screw assembly.
    • Screw the screw assembly to full extension and shortest extension to ensure lubricant reaches every section of the screw assembly.
    Ask FixBot
  7. How to Repair a Stuck Trailer Jack: step 7, image 1 of 1
    • Remove rust and corrosion from the upper and lower assemblies of the jack using a die-grinder and sanding pad.
    Ask FixBot
  8. How to Repair a Stuck Trailer Jack: step 8, image 1 of 1
    • Paint the upper and lower assemblies for prevention of future rust and corrosion.
    Ask FixBot
  9. How to Repair a Stuck Trailer Jack: step 9, image 1 of 1
    • During re-assembly, align the notch on the upper assembly to the grove on the lower assembly.
    Ask FixBot
  10. How to Repair a Stuck Trailer Jack: step 10, image 1 of 1
    • Use a hammer to force the upper assembly over the lower assembly.
    • Be sure to align the grove and notch of the assemblies.
    Ask FixBot
  11. How to Repair a Stuck Trailer Jack: step 11, image 1 of 1
    • Install the washer and the jack handle over the stud of the jack.
    • Insert the bolt through the handle and the hole located on the stud.
    Ask FixBot
  12. How to Repair a Stuck Trailer Jack: step 12, image 1 of 1
    • Install the jack to the trailer and test for correct operation.
    Ask FixBot
3 other people completed this guide.
2 Guide Comments
Thank you, very helpful. our tongue jack was a bit different looking but the principles were all the same, and with the help of this guide we got it fixed.
Loren Turner - Reply Share
What if the trailer jack is frozen in the position. And the gears on top are well greased?
Wesley Ramsey - Reply Share
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 293
All Time: 26,398
