How to Repair a Squareplug Patch Cable with SP400 Plugs
  1. How to Repair a Squareplug Patch Cable with SP400 Plugs, Patch Cables With SP400 Plugs: step 1, image 1 of 1
    • Verify that the cable is faulty (unresponsive yellow and green LED indicators).
    • Yellow LED indicator
    • Green LED indicator
    • If both the yellow and green LED indicators turn on, then the cable is not the source of any audio loss. Check the pedals, amp, guitar, or power supply for issues.
    • If the red LED turns on, then the cable is shorting and will also require a resolder.
    Ask FixBot
  2. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 2, image 1 of 1
    • Unscrew the SP400 housing.
    Ask FixBot
  3. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 3, image 1 of 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 3, image 2 of 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 3, image 3 of 3
    • Desolder the existing solder connections.
    • Wick the existing solder completely off of the plug connections.
    • Do not touch the plug or the wick directly while desoldering.
    • For more information on soldering, check out the How to Solder and Desolder Connections guide.
    Ask FixBot
  4. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 4, image 1 of 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 4, image 2 of 2
    • Cut the ends of the cable using a pair of wire cutters to expose fresh wires.
    Ask FixBot
  5. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 5, image 1 of 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 5, image 2 of 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 5, image 3 of 3
    • Strip the outer insulating jacket by ~1 cm.
    • The Eclipse UTP Stripper works especially well for this step.
    • Braid the ground wires.
    Ask FixBot
  6. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 6, image 1 of 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 6, image 2 of 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 6, image 3 of 3
    • Strip the inner insulator by ~2mm.
    • Braid the signal wires.
    Ask FixBot
  7. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 7, image 1 of 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 7, image 2 of 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 7, image 3 of 3
    • Tin the soldering iron tip, ground wire, signal wire, and plug connections.
    • Do not touch the plug or the solder directly while tinning.
    Ask FixBot
  8. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 8, image 1 of 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 8, image 2 of 2
    • Solder the wires onto the plug connections:
    • Signal wire to the tip connection
    • Ground wire to the sleeve connection
    • The outer insulating jacket should slightly extend into the chamber of the plug to minimize cable movement.
    • Do not touch the plug directly while soldering.
    Ask FixBot
  9. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 9, image 1 of 1
    • Screw the SP400 housing.
    Ask FixBot
  10. How to Repair a Squareplug Patch Cable with SP400 Plugs: step 10, image 1 of 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: step 10, image 2 of 2
    • Verify that the cable is working (responsive yellow and green LED indicators).
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 45
All Time: 1,173
