Up to 20% off select tools
How to Repair a Scratched CD
Views: 20K
View statistics:
Past 24 Hours:
16
Past 7 Days:
145
Past 30 Days:
682
All Time:
19,815
Comments: 0
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This technique works by using a rubbing compound that contains a grit to wear down deeper scratches on the CD. It also utilizes car wax to fill any remaining scratches, protect the CD, and keep the CD clean. Please note that this method will only work for CDs and DVDs, but will not work for Blu-Ray discs, as they are made of a harder material. Therefore, trying to wear down scratches with a rubbing compound would prove unsuccessful on a Blu-Ray disc.
    1. How to Repair a Scratched CD, How to Repair a Scratched CD: step 1, image 1 of 1
      • Rinse the disc with water and wipe clean to remove any dust or dirt.
      Ask FixBot
    2. How to Repair a Scratched CD: step 2, image 1 of 3 How to Repair a Scratched CD: step 2, image 2 of 3 How to Repair a Scratched CD: step 2, image 3 of 3
      • Apply a rubbing compound, moving from the center of the disc outwards.
      • Use enough force to create a mirror polished surface when rubbing compound application is complete.
      • We found that applying the rubbing compound for at least 30 seconds to 1 minute is sufficient.
      Ask FixBot
    3. How to Repair a Scratched CD: step 3, image 1 of 1
      • Let the CD sit for 5 minutes.
      Ask FixBot
    4. How to Repair a Scratched CD: step 4, image 1 of 2 How to Repair a Scratched CD: step 4, image 2 of 2
      • Wipe the CD clean with a new rag, removing any excess compound.
      Ask FixBot
    5. How to Repair a Scratched CD: step 5, image 1 of 3 How to Repair a Scratched CD: step 5, image 2 of 3 How to Repair a Scratched CD: step 5, image 3 of 3
      • Apply a thin coat of car wax directly to the CD, using a circular application method.
      • Apply in either small circular motions or large motions that follow the circumference of the disc.
      Ask FixBot
    6. How to Repair a Scratched CD: step 6, image 1 of 2 How to Repair a Scratched CD: step 6, image 2 of 2
      • Wipe the CD clean, removing any excess wax.
      Ask FixBot
Congratulations! You have successfully repaired the scratched CD!
9 other people completed this guide.
Author
with
Emma Larson
346 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 145
Past 30 Days: 682
All Time: 19,815
