Introduction
Use this guide for a last-resort cabinet repair when a leaking Frigidaire refrigerator has rusted through the outer skin near the evaporator area. You will open the damaged section, remove saturated foam, dry the cavity, and reseal the cabinet so moisture does not keep destroying the insulation and sheet metal.
Step 1 Disconnect power and clear work area
Unplug the refrigerator from the wall outlet.
Tape the ice maker and water supply lines away from the rusted section to keep the workspace clear.
Step 2 Remove the outer metal skin around rust
Score a rectangle around the rust, leaving a 2-3 inch margin, with a rotary cutting tool and metal blade.
Keep the blade shallow because the cabinet skin is very thin and separated from the foam.
Lift off the cut panel and any loose rust with needle nose pliers.
Step 3 Avoid damaging refrigerant lines
Stop cutting as soon as solid metal is clear to prevent piercing the refrigerant circuit.
Step 4 Thaw the saturated insulation
Inspect the cavity; ice-filled foam feels hard and reads cold on an IR camera.
Let the unit sit unplugged until the foam softens; overnight is usually enough.
Step 5 Excavate all waterlogged foam
Dig out dark, soggy insulation until only dry, light-colored foam remains.
Press on questionable areas; if water oozes out, remove that section too.
Step 6 Check and reposition the refrigerant pipe
Measure clearance and maintain roughly a quarter-inch gap between the pipe and the future back panel plane.
Gently push the pipe inward with a rubber mallet, wooden dowel, or fingers if it touches the metal.
Step 7 Refill cavity with low-expansion foam
Shake a can of moisture-resistant low-expansion spray foam as directed.
Insert the nozzle behind the pipe and fill the space from back to front in slow passes.
Step 8 Trim cured foam flush
Cut excess foam level with the surrounding cabinet using a serrated knife.
Step 9 Install a foam moisture barrier
Cut a flat sheet of closed-cell insulation to match the opening size.
Press the sheet into the cavity so it sits flush without overlapping the factory metal skin.
Step 10 Seal the patch with silicone
Run a continuous bead of silicone sealant around the perimeter of the new foam sheet.
Tool the bead smooth to eliminate air gaps and improve adhesion.
Step 11 Reinforce with metal HVAC tape
Cover the repair with overlapping strips of foil HVAC tape.
Press each strip firmly with a putty knife to lock the adhesive and remove air pockets.
Step 12 Restore power and verify repair
Reconnect any lines moved earlier and plug the refrigerator back in.
Operate the unit for at least one week while monitoring the patched area with touch or an IR camera.
Monitor the repaired area over the next several days and make sure moisture does not return behind the back panel. Repair didn't go as planned? Ask our Answers community for help.
