How to Repair a Resin Charm
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
81
All Time:
650
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Resin charms are a popular form of jewelry. Since they are made of plastic, they have the potential to snap. When this happens, they are usually considered trash, so we wanted to provide a guide that will help people extend the life span of this type of jewelry. Working with resin may even lead the viewer to start creating their own jewelry!
    1. How to Repair a Resin Charm, How to Repair a Resin Charm: step 1, image 1 of 2 How to Repair a Resin Charm, How to Repair a Resin Charm: step 1, image 2 of 2
      • Fit the broken pieces together with the flattest side of the charm facing towards you.
      Ask FixBot
    2. How to Repair a Resin Charm: step 2, image 1 of 2 How to Repair a Resin Charm: step 2, image 2 of 2
      • Lay a piece of tape on the crack and press down smoothly.
      Ask FixBot
    3. How to Repair a Resin Charm: step 3, image 1 of 1
      • Pick up the pieces so the crack is facing up.
      • Bend the pieces to create a slight gap.
      • CAUTION: Wear gloves when working with resin.
      Ask FixBot
    4. How to Repair a Resin Charm: step 4, image 1 of 2 How to Repair a Resin Charm: step 4, image 2 of 2
      • Add resin to the crack.
      • Press the pieces together.
      Ask FixBot
    5. How to Repair a Resin Charm: step 5, image 1 of 2 How to Repair a Resin Charm: step 5, image 2 of 2
      • Use a cotton swab to spread the resin in the crack.
      • Pick up the excess resin with a cotton swab.
      Ask FixBot
    6. How to Repair a Resin Charm: step 6, image 1 of 3 How to Repair a Resin Charm: step 6, image 2 of 3 How to Repair a Resin Charm: step 6, image 3 of 3
      • Turn on the UV light.
      • Put the charm under the UV light for 120 seconds per side.
      • Remove the charm.
      Ask FixBot
Now your charm is repaired and can once again be worn or displayed!
Jorja
133 Reputation
1 Guide authored
UC Davis, Team 2-7, Whithaus Spring 2024 Member of UC Davis, Team 2-7, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G7
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 81
All Time: 650
